Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
Question Closed
My MacBook Pro dosen't turn on
Yesterday morning, I spilled some coffee on my macbook. After a quick cleaning machines, I tried to know the damage. At first sight, there is the enter key and delete does not work anymore. I then opened the buttons and I cleaned and it works.
I used my mac all day until 6am without any worries. I turned off my mac and normally I wake up in the morning with surprise: my mac does boot.
I initially thought that my mac has no battery, I check the lights on the battery and they were all green (full battery). I tried plugging in the charger and the green light it. Pressing the button switch on has no effect.
I searched the internet and tried all the manipulations talking resetting SMC but seems no handling market.
I then opened my mac to try to disconnect the battery. I followed this tutorial :MacBook Pro 13" Unibody Mid 2012 Battery Replacement
but I stop at step 5 because I did not have the necessary equipment.I put everything back in place but now I have no sign of the battery. The charger does not light up when I connect it, I can not see the battery level and my mac still does not work.
What do you think?
Add a comment
1 Answer
Chosen Solution
Haytham - Doesn't sound to good here, time is your enemy when it comes to spills. Letting things stew only makes things worse!
I would recommend you get your system to a Apple authorized repair shop (not an Apple Store) as someone needs to open the system up and clean up the spill (tick! - tick!...) Likely you have some parts damaged here from the Coffee.
Apple would likely not repair it if the wet markers have been set off.
Good Luck!
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 597
