Comprehensive repair manuals on all portable tablet computers by Apple. Repairs are likely to require heat and careful prying.
5762 Questions View all
ipad is disabled, how to unlock it
there was a password on the ipad someone try to unlock it to many times and now it is disabled. how can I get back into it
Score 6
1 Comment
Have you tried to restore it under iTunes on the computer that you normally use?
by
Add a comment
1 Answer
Most Helpful Answer
Tiffiney, best would be to restore the iPad from within iTunes. You can restore with any computer, but you will lose everything on the iPad, unless you use the computer you normally sync with. . You will have to download all of your purchased content again after you unlock the device. You will also have to use recovery mode. for more info on that check on here. Hope this helps, good luck.
Score 4
Add a comment
Add your answer
Tiffiney will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 6,522
