Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Make a jumper instead of replacing the blue inductor coil.
The question is how do you make the jumper, you have to use soldering iron but what part is the one you have to weld? the whole "path"? just a part of it?
I attach a photo asking what part is the one to weld, the area in the red circle or the blue path.
If there is a guide on how to do that would be awesome!
Thanks.
-K
Score 1
1 Comment
please do report if it worked and please post a picture if possible...
by
Add a comment
Chosen Solution
krixx, in cases like the one shown in your image, I would suggest a circuit writer pen.
Score 1
6 Comments:
thanks, how do you use it?
by
Would it work on that black surface of my logicboard?
by
I don't see any reason why not. What you want to do prior to is to use a scalpel or Exacto knife, andcarefully remove the top layer of the shellac like covering. From what I can make out on the posted image, if you just want to bridge the contacts of the missing inductor, you will not have to do the scraping:-) Hope this helps.
by
Thank you so much :)
by
Show 1 more comment
Add a comment
The answer to your questions, how to fix the blue inductor coil causing a signal problem, the solution is easy we have repaired many with a 100% success rate. If you look at the signal antenna which you plug the cable into, simply run a wire from the left side bridge it to the right side point on the blue coil and follow it all the way to the furthest (right) component on the top left side. This will act as a 'bypass route' and your signal will start to work again.
All it takes is a bit of micro- soldering knowledge and some 0.1mm wire and basing soldering equipment. This will fix your problem guaranteed, providing it was the missing blue coil that caused your signal issue in the first place.
Kind regards,
Ideal mobiles
Score 1
Add a comment
what happens if i mess up
can i bridge them 2 circle connectors together to get signal
many tnx
Add a comment
Add your answer
Carlos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 7,983
