Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
How to apply a jumper to the blue inductor?
hello DEAREST @johnkustic PLEASE HELP me
how can i jumper it ? please ?
recieved iphone 4 after water damage with erro -1 in itunes
now its fixed
but constently losing wifi/gsm signal
the phone has imei and all ,please help me if you can
with what wire can i use to jumper it,its too close to another fuse ,
you saID YOU made a jumper with soldering iron ,since its too small i guess you only implemented soldering iron and thats it ?
can it also be the bb or other coil?
can you please answer me ?
Score -1
Add a comment
Most Helpful Answer
Hey 7Gnosis Sorry for late reply did not see your post. Just use regular soldering iron, soldering wire and no clean flux. Just apply little bit of flux and after melt soldering wire to connect the two points where blue coil is missing.
Hope that helps.
Score 3
2 Comments:
@Johnkustic
Hi, a have a same issue. crap blue coil is missing i have solder a Jumper today but no luck. still no Service /Searching may be is wrong soldering. Do U have any pix with the Jumper on this Place . I tried with conductivity silver before there was the same will try again tomorrow
thank you Etienne
by
Thanks John, works like a champ! A customer of mine damaged her phone with a home repair. I did not need to run a wire as posted by some others. Simply cut a piece of small solder and laid it where the blue coil once was and voila.
by
Add a comment
The answer to your questions, how to fix the blue inductor coil causing a signal problem, the solution is easy we have repaired many with a 100% success rate. If you look at the signal antenna which you plug the cable into, simply run a wire from the left side bridge it to the right side point on the blue coil and follow it all the way to the furthest (right) component on the top left side. This will act as a 'bypass route' and your signal will start to work again.
All it takes is a bit of micro-soldering knowledge and some 0.1mm wire and basing soldering equipment. This will fix your problem guaranteed, providing it was the missing blue coil that caused your signal issue in the first place.
Kind regards,
Ideal mobiles
Add a comment
Add your answer
7Gnosis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,158
