The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154 Questions View all
How to fix door handle?
I want to repair my drivers side exterior door handle the part thtat you grab to open the door broke and glue does not hold it. 2002 altima
Score 2
Add a comment
Chosen Solution
Removal and Installation EIS003IU
REMOVAL
1. Remove the front door window and front door module assembly.
2. Separate the key cylinder rod and exterior handle rod connection (on the handle) if equipped.
3. Remove the screws (TORX T30) and the door lock assembly.
4. Disconnect the door lock actuator electrical connector.
5 Remove the exterior handle bolts, move the exterior handle assembly backward, and then remove it from the panel in front of the exterior handle escutcheon.
Installation is in the reverse order of removal.
CAUTION:
To install each rod, be sure to rotate the rod holder until a click is felt.
Score 5
Add a comment
I have changed both of the front door handles on my 2004 Nissan Altima. The parts that I ordered on Amazon were perfect, and even color matched! I followed a step-by-step video produced by 1AAuto.com and I had no issues. I will warn you, if you are new to these types of repairs, it can be a little bit tedious!
Score 2
Add a comment
Add your answer
Chiquila will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 18,878
