Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
274 Questions View all
Tried inverter what's next?
Hello I have a Imac 20" A1207 Intel with and I cant' get a my display to show anything. I have replaced my inverter board but it didn't help. What should my next step be to replace the lcd data cable or the lcd itself? I have no backlight or lines on my lcd it is simply black. My logic board shows the first 2 leds and the white "spot light" and fans run full speed. Any help would be appreciated thank you in advance.
Matt
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
LED #2 "flashes" then #3 should come on. If you've already reset the SMU and LED 3 is off, it means that your logic board needs to be replaced.
If this answer was helpful please remember to return an mark it Accepted.
Score 1
Add a comment
Add your answer
Matthew Hefner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 277
