Repair and troubleshooting information for the Suzuki FA50 Moped.
Why won't it start?
My fa50 won't start. It gets good spark,gas,air,and air compression. Why won't it start?
Score 2
4 Comments
What have you tried so far? Tried to squirt a bit of gas into the spark plug hole and try to start it, just to make sure it does get fuel?
by
yes but dies once gas burnt
by
jwhiteboy68, is this the same moped? Are you rodneylambert45? Just making sure we are dealing with the same issue here.
by
Here to, won't start normal ,does wel with startpilot at airfilter. When warm motor ,starts fine with kick only.
by
Add a comment
Most Helpful Answer
the main jet needs to be cleaned in the carb .. take off the carb and clean it out
Score 2
Add a comment
Sounds as if you are not getting fuel from the carburator into the cylinder correctly, if it were me, I would remove and then clean that carburator by use of some instructions from a repair manual.
Score 1
Add a comment
Add your answer
rodneylambert45 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 3,061
