iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
09 motherboard broken, can I replace to quad core 2011 motherboard?
I have to replace the motherboard on this after breaking the LCD display attachment. It's going to cost about the same to replace with the same motherboard w/o CPU vs buying a replacement motherboard with an i5 CPU for a 2011 27 iMac.
Since they look like they are the same form factor, can I just buy a motherboard for a 2011 27" iMac and stick it in my 2009 iMac 27" iMac? Are the other components compatible? Will there be issues with the GPUs?
thanks.
Add a comment
Chosen Solution
If the logic boards were able to be swapped the processors would not present a problem...I see an '09 as aniMac10,1 while '11 is an iMac12,2. I would contact the vendor before purchase and see if they confirm the swap, and guarantee it.
Your old HD might be a problem, the '09 was SATA II the '11 is SATA II (but SATA is backward compatible-however sometimes theory and reality don't intersect as predicted) and there'd be firmware updates necessary after you got the machine booted.
If this answer was helpful please remember to return and mark it Accepted.
Score 1
2 Comments:
Thanks for the reply. The link you posted was helpful, but it's comparing the 2010 imac to the 2011 imac. My question is this - can I use a 2011 quad-core logic board in a 2009 core 2 duo 27" imac? They look like the same form factor.
thanks.
by
Look farther into the site, do a side/side comparison and Pete Dinh - For future reference you posted a comment in the place where only Answers belong. Please use the Add Comment link, or update your Question
by
Add a comment
I had an issue with one of the sensors that is not on the older motherboard (2009) Still can't figure it out how to solve it, otherwise everything else works perfectly.
1 Comment:
what was the new motherboard? did you manage to fix it eventually?
did you replace anything else as well?
by
Add a comment
1 Comment:
I need to buy another iMac. That's good.
https://fireboyandwatergirl.games
by
Add a comment
If you don't have a big difference in the price of a new one, think of a new one.
https://basketballlegends.fun
Add a comment
Yes , you can change motherboard. But Firboy and watergirl will also work on the this motherboard
Add a comment
Add your answer
Pete Dinh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,011
