MacBook Pro models with a 15" display
8251 Questions View all
Question Closed
What part of the screen is causing this problem?
My son brought my old laptop to his cousin's house (not in a laptop bag mind you). He doesn't remember dropping it but now the screen is doing this:
http://flic.kr/p/d2WLyd
Opening and closing the screen doesn't change the pattern (trying to rule out a loose wire).
Thoughts?
Add a comment
Chosen Solution
This issue is a damaged LCD display. Below is the guide to replacing the LCD display (Assuming your Macbook Pro is a Pre-Unibody model judging by the picture)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
Hope this helps,
Score 1
1 Comment:
Thanks, new LCD on order!
by
Add a comment
Most Helpful Answer
I dont think that a loose wire would have that effect. That seems to be a cracked screen.
Score 1
3 Comments:
The LCD looks perfectly normal when off. Cracked from the inside?
by
One of the layers of the lcd screen is most likely cracked. I just searched MBP cracked screen and the images returned look a lot like the issue you have, eg.
http://www.daytonanetworks.com/wp-conten...
by
If you want to make sure that the issue is not GPU, cables or connections related, hook it to an external screen.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 379
