Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Questions View all
Question Closed
iMac stuck on white screen, gear stops spinning
My 2008 24" iMac has stopped booting up all the way. When I hit the power button I do get the chimes that play, and I get to the white screen with the grey apple, however after a few seconds the gear stops spinning.
Here's what I've tried so far:
1. Holding down Shift while booting: get progress bar, but gear eventually stops booting
2. Holding down Option: I get Mac HD, Recovery HD, and Install Disk. Choosing any of them gets me back to white screen, and gear stops spinning.
3. Holding down Command + Option + P + R: Causes reboot, boot after that gets me to white screen, gear stops spinning.
4. Holding down C to boot directly to install disk: Same result, gear stops spinning after awhile.
5. Leaving iMac unplugged for a few hours. Same result.
I'm pretty desperate at this point. I'm looking for any ideas.
Add a comment
1 Answer
It almost sounds like your hard drive has died. If you can boot to an external, that would (should) confirm it. Based on your description, I don't think is the system / mother board.
1 Comment:
But I can't boot to the install disk or external. I get the same result when choosing either of those.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,498
