Samsung Galaxy Camera Lens and Motherboard Replacement
  1. Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
    Samsung Galaxy Camera Lens and Motherboard Replacement, Screen: step 1, image 1 of 1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Lens and Motherboard Replacement: step 2, image 1 of 1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Lens and Motherboard Replacement: step 3, image 1 of 1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Lens and Motherboard Replacement: step 4, image 1 of 3 Samsung Galaxy Camera Lens and Motherboard Replacement: step 4, image 2 of 3 Samsung Galaxy Camera Lens and Motherboard Replacement: step 4, image 3 of 3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Lens and Motherboard Replacement: step 5, image 1 of 1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Lens and Motherboard Replacement: step 6, image 1 of 1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Lens and Motherboard Replacement, Lens and Motherboard: step 7, image 1 of 1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Lens and Motherboard Replacement: step 8, image 1 of 1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Lens and Motherboard Replacement: step 9, image 1 of 1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Lens and Motherboard Replacement: step 10, image 1 of 1
    • Lift the motherboard and lens out of the case.
10 other people completed this guide.
Richard Hicks
1,262 Reputation
4 Guides authored
USF Tampa, Team 1-3, Sullivan Winter 2015 Member of USF Tampa, Team 1-3, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G3
3 Members
4 Guides authored
One Comment
Hey mate, what do you do after the motherboard replacement? Just turn the camera on? Do you need to do a master reset?
Sam - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 5,016
