iPod Video Color Display
$19.95 Was $29.95
You save $10.00!
Product code: IF195-000-2
Product Overview
The sage who said "seeing is believing" had clearly watched David Blaine's DVDs, but failed to view the deleted scenes. Glimpse the virtue of vision today with our iPod Video color display.
This screen can be installed in any 5th Generation iPod Video.
Compatibility
Identify your iPod
  • All 5th Generation iPods (iPod Video)
Product Details
  • Size: 2.5" (diagonal)
  • Resolution: 320x240
  $19.95 Used
Condition:
Used, fully tested
Warranty:
6 month warranty
Add to Cart »
46 Available
Quantity:
Compatibility
iPod 5th Generation (Video)
30 GB
60 GB
80 GB
Stories
My Problem
quebrado.
My Fix
muito facil, ja tinha visto em videos
My Advice
nao
My Problem
Überhitzung des Prozessors, Überlastung (Stillstand des Systems) des Prozessors
My Fix
Recherche, Einlesen in die Materie, eingehende Studie der Informationen und Anleitungen, lesen der Erfahrungsberichte in Foren und auf Webseiten zu ähnlichen Problematiken,
anschließend Bestellung der Teile und reibungsloser Umbau, Dank detaillierter Beschreibung und hochauflösender Bilder UND natürlich Dank bester Produktqualität!
My Advice
Detailliertere Beschreibung der Problematiken; Überleitung von Problemstellung zur passenden Anleitung:
du hast "dieses und jenes" Problem? Ok: versuche folgende Anleitungen...
My Problem
iPod Fifth gen lost pixels on screen
My Fix
Very well. Loved the great tools. And the how to step by step guides are fool proof.
My Advice
Read everything fully twice. Measure and check twice. Do once.
My Problem
IPOD 5 worked fine but screen was cracked
My Fix
Your guide a big help. Couldn't have done the repair without it
My Advice
A hands free high power lighted magnifier was a huge help in doing the job correctly.
My Problem
My colleague told me of his problem of a broken screen in his iPod video, and I volunteered to fix it for him.
My Fix
I took it apart before ordering a new one to see how it would go and if I had all the proper tools. The guide was spot on and made the tear down relatively simple. I have fixed iPod touches befor and this was WAY easier. The ribbons are not soldered but clipped instead. The guides from ifixit are great!
My Advice
I would advise anyone thinking of fixing an iPod video, to do it. You just need a little patience and ability to follow the instructions in the guide. It's pretty easy.
My Problem
My display was unreadible when the back light was on.
My Fix
The repair was easy, I did not have to unplug anything besides the screen. This is the second time I've repaired my IPod using parts from this site, once again it saved me from buying a new one.
My Advice
They don't send you tools, but besides prying the case apart you may not need them depending on the part.
My Problem
Wanted a high capacity ipod for music, and my brother had one. Problem was that it had a broken screen. So he gave it to me for free and left me to repair it.
My Fix
After my brother told me about this website, it was very easy. Bought the parts, and added a battery along with it, you know... just in case. It shipped quickly and installed it that day using the guide to make sure I didnt do anything asinine.
My Advice
My advice is to use this site, and also to make sure you buy the right tools. It makes it much faster and easier and more reliable to repair things.
My Problem
the battery exploded and broke the LCD screen
My Fix
repair went smoothly with the guide on ifixit worked 100%
My Advice
be careful when removing the ribbons from the board could be damaged very easy
My Problem
The battery, on my first gen. and already 8 y.o. Ipod 30Gb, wasn't holding is charge anymore (almost). I heard about Fixit in early 2012. I decided to give it a try and to give a second breath to this long time travel friend.
At the same time, I replaced the color display, because it had start to fade. Being there for the battery was the perfect timing to replace it.
My Fix
The repair went good. I took more time than it should, because I didn't want to make it worst than what it was. Removing the front panel was the "most" delicate operation. After that, it went really good.
I was a bit disappointed while replacing the color display. This operation went almost flawless. But not having a small replacement strip for the electrical tape, like the old one protecting the welding spots (print circuit) against the alu. frame. I had to delayed the installation to the mext day, after bying some special tape. The rest went also very good.
My Advice
Be patient with the front panel! Take your time to look at the things, TWICE, before you pull to hard...and read the very well done guide. It's almost idiot proof!!
My Problem
My 6-year-old iPod Video had started flaking out on me when the headphone jack started failing. The battery hadn't been holding a charge for more than half an hour, either, and the display had a few dead pixels from being dropped a couple of times. Yeah, it needed some work.
My Fix
The repairs went pretty well! I'm actually glad I cracked it open using the iFixit guides or I wouldn't have noticed the logic board needed replacing too. I got it from another seller because it was out of stock here, but followed the instructions here for every part (battery, display, headphone jack & logic board) and my iPod is back to life!
My Advice
My advice is be patient and follow the guides. If anything goes wrong, the guys on the phone line are real nice, too!
Related Questions
1 Answer
0 Score
How do I fix a scratched screen
