Click Image To Zoom
Installation Guide
iPhone 3GS
Difficulty: Very easy
Required Tools Add All Tools to Cart »
Spudger
$2.95 ·Add to Cart »
Metal Spudger
Small suction cup
Share this Product
Stories
My Problem
Broken display on 3gs 32g & 3g 8gb iphone
My Fix
it was well success :-)
My Advice
My use fixiit guide :-)
My Problem
I had dropped my phone cracking the screen. Still worked, just cracked. A friend gave me theirs which I dropped in a puddle, making the dock connector and home button not work, so I used the module from my phone. I then had a phone fully functional and one with a cracked screen and broken dock connector and (I would notice later after fixing) a torn ribbon connecting the camera.
My Fix
Fixed the screen and dock connector and, with the exception of the camera I still have to fix, works great! Looks like new with the screen.
My Advice
Keep aware of the camera ribbon when pulling out the logic board. Also, invest in a good case.
My Problem
A customer dropped her 3GS and didn't want to pat AT&T $200.
My Fix
It was easy, I got the whole front assembly for her because I didn't want to have to transfer the home button and speaker over.
My Advice
Just take your time
My Problem
Son dropped his phone
My Fix
I tried 2 other "replacement" panels from other vendors, and neither worked. The connector 2 plug was not correct
My Advice
Buy from iFixIt if you want to get the right part the first time.
My Problem
My wife's iPhone 3GS fell into a concrete floor few days before the 4s release, coincidence?.
My Fix
It was hard at first time, but the videos help a lot. I did not install properly one of the connectors and I had to unmount the iPhone again.
I bought the full front panel to avoid dissasembling just the touch screen so the fix was not that hard.
My Advice
Be calm, think it twice and watch the ifixit video tutorial.
My Problem
Phone dropped at airport during pre-flight security screening.... Empty your pockets, remove your jacket, remove your hat, remove you shoes, remove your glasses, remove your belt... CRASH
My Fix
Much, much slower than on your video.... Are you sure MJ isn't related to Bat Woman or some other supra terrestrial individual? Intense staring at the screen also failed to deposit her phone number into my iPhone contact list!
My Advice
For the tool kit for this job you should add (1) A 6X hand-held magnifying glass. Helps examine cable sockets for correct alignment / damage when connecting cables (2) A pair of fine-point tweezers for handling screws and small parts (3) The Phillips screwdriver should be magnetized to retain screws for initial threading.
My Problem
The home button on my iPhone 3GS stopped working, and the coating wore off so if you breathed near it, it would fog up.
My Fix
It went very well, although even though i bought the phone new and never opened it before, there were some strange things that the factory (apparently) did/didnt do on the innards. There was an extra screw just sitting around inside the case, not missing from anywhere, and the reported black tape securing the digitizer to the screen also didnt exist.
My Advice
I wore latex gloves, and was armed with compressed air and screen cleaner, and it helped very much to keep the grit and grease out of the inside of the device. The first time i put it back together i realized a hair got trapped between the screen and digitizer, so i had to re-dismantle and re-assemble it, after that all was well.
Related Questions
| 2 Answers 0 Score | Is the digitalizer the same connector on a 3g as the 3gs | |
| 1 Answer 0 Score | Recommended parts to repair off switch, silent switch & home button? |
| 1 Answer 0 Score | I ripped the ribbon connector & the touchscreen feature does not work |
| 2 Answers 1 Score | Broke screw bracket on bottom of iPhone | |
| 3 Answers 0 Score | My ear speaker does not work |
