Stories
My Problem
pushing the power button did not put the iphon in stand by , nor long pressing the button trigger the power off .
My Fix
repair when fine thanks to the ifit guide , and photos.
but I got a new button and it's not fixing the pb....
My Advice
may not fix your pb
My Problem
In one of the rare times I had my iPhone 3GS out of its leather case, I dropped it on a tile floor. The chrome Power Button came loose and disappeared, forcing me to have to sleep the iPhone by trying to depress the remaining part of the button with a fingernail - not easy.
My Fix
I looked at the instructions for replacing the switch on iFixit.com, which were certainly complete, but would have required quite a bit of delicate work.
I spotted in the remaining part of the switch a slot in which the chrome button cap must have been pressed. Since the cost of the part, through iFixit.com, was quite affordable ($5), I ordered one. The part arrived quickly. Upon its arrival, I easily - by hand - was able to pull off the chrome button cap from the new switch assmebly and, simply, press it into place where the original had been.
All fixed!
My Advice
Easy repair, without requiring disassembly of the phone.
My Problem
A friend of mine had a broken down iPhone 3G. The phone itself was in kind of rough condition. The power button was torn off, the LCD has lines across it and the battery wasn't holding a charge anymore. I figured that before sinking money into a replacement screen, fixing the battery and switch should be done first.
My Fix
The repair went smoothly following the guides. Just lift up on the contact cables and don't push on them like a nut like I did. It was a great confidence builder and the tutorials were great. Of course, now I know that I have to buy a replacement for the internal power switches as well as a new LCD.
My Advice
I went out to the local hobby shop and bought a little paint mixing disk. The kind with indentations. I numbered each of the 10 reservoirs and add the screws and bits to them in order. It made it a lot easier to find things. I just need to weigh it down so a hard breeze doesn't send it flying.
My Problem
the could not use the touch screen.
My Fix
The repair took some time but the step by step instructions are great on ifixit.com. The parts where exact and high quality.
My Advice
If you need to repair or replace your iPhone battery or front glass, some pointers. The front glass is relatively simply, but the battery is a little harder. But ifixit online step by step you can get thru it. Word of advice, do not buy iPhone parts from ebay or amazon, buy from here. At Ifixit you know your getting high quality items, my touch screen works like original. Also the parts are very small, so if the part being off by just a little will be hard to put back together.
My Problem
My 3GS is over three years old, battery was completely shot, it would die between 100% and 80 - 85% life. Also the power button seemed sunken in and weary, decided to spend the extra five bucks on new power button as well.
My Fix
Printed the repair guide for battery replacement and power button replacement, followed everything step by step and the battery installation and power button replacement went perfectly. i even feel like my iphone is more well put together than before i reassembled it.
My Advice
if you think you are one of those people that can diy, go for it its pretty exciting and fun if youre a nerd like me haha. make sure you dont lose any tiny little screws. sucks trying to find them from off the floor.
My Problem
The volume button had fallen off and the power button was non-functional
My Fix
As this was my first iPhone (3GS) repair, the process took a long time (approx. 3 hrs?). Battery replacement on 2 others took 45 mins, then 20 mins.
My Advice
iFixit guides were good but they could be great:
Step 4 could suggest running the spudger UNDER the black ribbon labeled 1. This make is a lot easier.
Step 6 was the most difficult to understand since the picture doesn't show enough detail and the tab that lifts up is so tiny. I could not get the tab to lift up. I ended breaking a small piece of the plastic past the tab. Luckily it had no apparent effect. I would suggest a simple drawn diagram showing the location and position of the tab before and after it is lifted.
Also, one washer came off of one screw, but I had to idea which one.
My Problem
To be honest, there wasn't any problem regarding my iPhone 3GS, it was working well. However, the power button seemed a bit "tired", and my battery didn't last as long as before.
My Fix
Overall, it went very well. I had trouble opening up the phone, and I had to remove the screen protector I had placed, and then use the Section Cup to open up the phone. I also had trouble with the "Do not remove" adhesive, it tore apart into small pieces. Everything else regarding disassembly and re-assembly went well. However, I am disappointed about the replacement power button. It simply don't work. It didn't clicked when I pushed it. I kept the old one, and when comparing the two, it seems that the one IFixit sell is some cheap chinese copy. The Apple one has totally flat back plastic which allows to press the electronic part as it should, when the other one has a back plastic filled with holes and industrial marks. On a good note, the battery is as good as the original one.
My Advice
The screws looks like they are all the same (except the two from the case). I recommend writing on a paper "Yellow, Orange and Red", and put the screws on it according to the repair guide. It really helps when re-assembling.
My Problem
My sister broke here iPhone 3GS dropping it.
My Fix
It took quite some time to do all the necessary steps, but thanks to the detailed guides the repair was a success. Even though I never did this before.
My Advice
There is nothing to add to the guide "Installing iPhone 3GS Rear Panel" - thanks a lot guys!
My Problem
The headphonejack, the mutebutton and the on/off switch were out of order.
My Fix
The process was quite clear (except the mute-switch) but to get those tiny screws back into place was terrible, used one hour for one screw near the muteswitch.. I found out that I needed a little magnet to let the screw hang under the philips screwdriver. I took the bike, full speed, to a hobby/model shop in my neighbourhood in Oslo and they gave me a tiny magnet, 4mm x 2mm x 1mm, I got it just before closingtime on saturday and I could finish the repair within half an hour. The magnet is small enough not to disturb and strong enough to make the screwdriver magnetic.
I could not repair the nutebutton, This part is complicated and the instruction and pictures could be better and more clear
My Advice
Together with the screwdriver you could sell such a little magnet. The screws are very easily to remove when taking apart and as easily to get back into place when the magnet sticks to the screwdriver just 1 or 2 cm above the screw. I would never have managed without.. ..or loosing my temper completely.
My Problem
My teenage daughter, like most teenage daughters, cannot service without her mobile communication device. In her case, it is a hand-me-down iPhone 3GS. Through repeated overuse, the top part of the power button had fallen off. She had to resort to using her fingernails and teeth when turning it on or off. She bugged me for weeks to get her phone fixed.
My Fix
I may not be the handiest guy around but that has never stopped my from trying. I came across the needed part on iFixit's website and the step-by-step instructions. I decided to give it a shot and ordered the part. I figured if I broke anything, the 3GS is so cheap these days that I could easily replace it if I broke it.
My daughter assisted me during the "surgery". As I removed the front glass my daughter's apprehension showed, and it increased as I pulled the phone apart piece by piece.
Everything went smoothly until I tried to replace the actual part that was the problem. The part consists of a rectangular metal swivel, a black plastic piece, and a silver top. When it tried to install it, I couldn't get it to engage the power "switch" that it pushes against correctly. I tried for about an hour but just couldn't get it to fit correctly. It looks identical to the original piece but perhaps it differs slightly to some degree. The rectangular metal swivel is supposed to swivel all the way to a right angle one direction, and about 130 degrees the other way. The replacement part seemed to swivel 180 in both directions but I couldn't see how that affected anything.
After fiddling with it for about an hour I decided to take the silver top off of the replacement part and glue it on the original black base since I still had that. I used a dab of Gorilla glue and clamped it together with a paper clip for about an hour. The original piece went back into place with no problem.
With iFixit's instructions, I was able to put it all back together and got it working like brand new. When my daughter got up the next morning (she went to bed while we were waiting for the glue to dry) she was so excited that her phone was like new again. She exclaimed "It's the best day ever"! That was until the next day when her Grandfather got a new iPhone 4S, passed his iPhone 4 down to her, and she passed the 3GS to her Grandmother. Then that was the best day ever!
My Advice
I'm not sure what the difference was between the bases on the original part and the replacement part but once I took the silver top off of the replacement part and put it on the original base, the power button went back in with no problems and engaged the on/off switch on the inside with no problem whatsoever.
Anyway, thanks to iFixit, for less than $10 and a few hour's time, I was my daughter's hero again, at least for a day, until her grandfather passed his iPhone 4 down to her. Then he became her hero!
Related Questions
| 2 Answers 0 Score | Screen flashes apple logo. Wont turn on |
| 11 Answers 0 Score | iPhone 3G power button | |
| 2 Answers 0 Score | On/OFF Button on top missing | |
