iPhone 3G and 3GS Vibrator
$4.95
Product code: IF137-015-1
Product Overview
Vibrator apparatus allows for quiet ring notification.
Compatibility
Identify your iPhone
  • All 3G and 3GS iPhones
Product Details
  $4.95
Condition:
New
Warranty:
6 month warranty
Add to Cart »
16 Available
Quantity:
Installation Guides
iPhone 3G
Difficulty: Moderate
iPhone 3GS
Compatibility
iPhone 3G
16 GB
8 GB
iPhone 3GS
16 GB
32 GB
8 GB
Stories
My Problem
The silver piece broke of the mute switch rendering it useless and the phone can't be switched to vibrate.
My Fix
Repair took about an hour. I went slowly and steadily through the teardown.
My Advice
PERFECT! Take your time and be methodical and it is pretty straight forward to get as deep as you want into the iPhone internals. This repair requires the removal of a fair bit of the internals to properly reach and remove the switch.
My Problem
My iphone suddenly stopped vibrating
My Fix
Very smoth repair considering It's the first iphone I was brave enough to open. No problems with the instructions but things could have run smoother if pictures in the pdf version of the manual were in HD. Some details ar important so as not to damage sensible or delicate conections. My internet connection was not very good and that's why the pdf version was prefered.
Other than that everything went ok in little less than an hour. The big deception was that everything done, the vibrator continued not functioning and now things are dark again.
My Advice
Then again, HD pictures would be helpful... a lot!! And of course, nobody said anything about the soft foamy material under the numbers on the connectors that I almost peeled off thinking those were the connectors. Sorry!! not all of us are technicians and know what the manual is talking about. Ohhh yes!! almost forgot to suggest you people to include a pair of tweezers to hold and position the screws, which are really tiny. That was my biggest difficulty. Also a good light source is useful, especially when you pop open the iphone and have to hold it partially open to prevent breaking off the fist three ribbons on the connectors.
My Problem
3GS stopped vibrating after hitting the floor from shoulder distance
My Fix
Quite easy repair, the only hard part is to get the screws back into their positions .. Soooo small!
My Advice
Nope
My Problem
i had my 3GS in my front pants pocket at work and just happened to turn a corner too sharp and my phone was in between the stationary counter corner and 220 lbs of quick moving guy (me). after this minor encounter, the mic no longer worked, the speaker has a mind of its own and works less than a DOT employee, and at times the Home button and/or the Power button will not get the display to light up. And even before this, the vibrator was intermittent. Hence, i knew i had some problems.
After doing some online research and watching the tutorials on ifixit.com, i figured it was worth a try to repair it myself - how hard could it be?? i ordered a replacement Dock Connector, Vibrator, and spudger to perform the repair.
My Fix
I never would have attempted to do this without the help of the ifixit tutorials, and the quality of instructions and photos were excellent. however installing the replacement parts didn't solve my issues, PLUS i couldn't get the phone to charge and the Home button did not work with the new Dock Connector. I opened it back up to check all the connections were in place (they were), and when it exhibited the same symptoms after this, I decided to reinstall the original Dock Connector so that I could at least charge my phone. Being a student and in class most of the time, my phone being essentially an iText worked okay for me - for the short term.
At this point, I have reset my phone via the option in the Settings menu, and since I have backed it up on my iTunes, I have also tried to both restore it as well as restore & update it via iTunes. Unfortunately this doesn't work too well since I am having the typical iOs 5 download timeout issues, and I haven't figured out how to restore my phone via iTunes without automatically trying to update it. The crazy thing is that since I reset it on the Settings menu, it has regained some of its original functionality (but not all) so I am in a quandary about what exactly to do. I am leaning towards reinstalling the new Dock Connector again, however I am concerned that I can't find any guidance about just how much handling the ribbon connectors will handle.
My Advice
Even though I have a giant toolbox with about 14,382 different screwdrivers and various hex bits, I wish I had just purchased the #00 screwdriver with the rest of the parts, since the two other ones I have since purchased work even worse than my good #0 screwdriver that I initially used. My other concern would be using a magnetic tip to get the screws into place - does this present a problem with erasing any of the phone components? I hope not, because with my big fingers, i couldn't figure out another method to get most of the screws into place (especially the two Dock Connector screws).
My Problem
Vibrator broke once I thought I fixed it with old one.
While in there i'm replacing battery also
Contract not up yet
My Fix
Repair went well everything back together and working.
My Advice
Go for it easy to follow instructions
My Problem
It suddenly stopped vibrating one day.
My Fix
Super smooth. The guide from ifixit was amazing. Very simple and easy to understand.
My Advice
A very important instruction was missing at the end of the guide. Once you rip apart your iPhone completely and fix it back there's no way that your iPhone would switch on unless you hard reset it.
I was very worried to see my phone not switching on after i replaced the vibrator and fixed everything back in place. I had to go through some stuff on the internet to find out that i had to hard reset it for my phone to start running.
Related Questions
