Samsung Galaxy S III Teardown
Teardown
Teardown
Teardowns provide a look inside a device and should not be used as disassembly instructions.
Anxious to have the Galaxy S 3 in the palm of your hand? Join us as we take an exciting sneak peek at the Samsung Galaxy S III, the appropriately-named successor to the Galaxy S II. Images provided courtesy of Chipworks!
Follow iFixit on Twitter if you're keen on getting the latest updates on our teardowns!
Image #1
Add Note Edit Step 1 — Samsung Galaxy S III Teardown  ¶
  • First, let's give thanks where thanks are due: a big, solid, awesome thanks to Chipworks for providing the pictures for this teardown. We greatly appreciate their help for the Samsung Galaxy S III!
  • Here's their full analysis on the Galaxy S III.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Arguably the most hyped-up Android phone to ever hit the market, the Samsung Galaxy S III has an impressive list of accolades. Here are some of the heavy-hitting tech specs:
    • Android 4.0 Ice Cream Sandwich
    • 4.8" Super AMOLED 720 x 1280 resolution display
    • 1.4 GHz quad-core application processor
    • 2100 mAh battery
    • 8 MP rear-facing and 1.9 MP front-facing cameras
    • 16, 32, or 64 GB of internal storage
  • Pictured here next to the Samsung Galaxy S2 (left) for comparison.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • The simple, sleek design of the newest Galaxy S implements a standard power/sleep button on the side of the device.
  • As we ready ourselves to dig into this Galaxy S, it watches us with its rear 8 MP camera. To the left and right of the camera are the flash and speaker assemblies.
    • The Galaxy S is not only watching us, but listening, as well.
Image #1 Image #2 Image #3
Add Note Edit Step 4  ¶
  • Much like in the Galaxy Nexus, we find a user serviceable battery in the Samsung Galaxy S III.
  • The 3.8 V, 2100 mAh battery incorporates the antenna for the Near Field Communications (NFC) module used in "S Beam".
    • For those who are curious, 2100 mAh is equivalent to 7560 Coulombs of charge. Unsurprisingly, this is the same amount of charge that a 3.8V, 7.98 Wh battery holds.
  • Well this is interesting. It would seem Samsung wants us to "refer to [the] manual before using [the] battery?" Yeah, like that's gonna happen...
Add Note Edit Step 5  ¶
  • Internals time. The spudger takes care of the first two plastic assemblies.
  • The first piece out is the rear plastic frame that protects the motherboard and houses a single liquid indicator sticker.
    • Should your Galaxy S III ever take a swim, be sure to stick it in one of iFixit's Thirsty Bags.
  • Removal of the frame grants us access to an easily replaceable speaker assembly.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • The big question now is what we should remove first. So many components in such a small volume!
  • Rear-facing camera you say? Sure, let's pry that 8 MP behemoth of a camera out from the inner framework.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • We continue by removing the motherboard from the inner framework.
  • With the motherboard out of the way, we can get a good look at the inner support frame. While we suspect that the frame is probably magnesium, we do not yet have any concrete proof.
  • We find a chip that isn't attached to the motherboard: a Melfas 8PL533 Touch Sensor that translates your touch inputs into zeroes and ones.
Add Note Edit Step 8  ¶
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPad 2 Front Panel Assembly
$134.95 · 50+ In stock
iPhone 5 Liberation Kit
$9.95 · 22 In stock
Heavy-duty Spudger
Heat Gun
$24.95 · 21 In stock
Precision Tweezers Set
$7.95 · 37 In stock
