Click Image To Zoom
54 Bit Driver Kit
$59.95 Was $80.00
You save $20.05!
Product code: IF145-022
Product Overview
The key to getting inside modern hardware.
  • The comprehensive standard in precision screwdriver bit sets, features 54 carefully selected bits—chosen with data collected from our thousands of free repair guides.
  • This kit forms the base of our popular Pro Tech Toolkit, the industry standard for computer repair technicians and businesses.
  • Available in an elegant and rugged magnetically-sealed wooden case.
If you're looking for replacement or legacy bits, or you just want larger and even more rare bits, be sure to also take a look at iFixit's Macro Bit Set and 4mm Screwdriver Bits. If you're looking for a slick ratcheting screwdriver that fits all the bits in the 54 Bit Driver Kit, check out Frictionless Ratchet.
Kit Contents:
  • 4 mm Aluminum Driver - featuring a magnetic socket, rubber grips, and a ball-bearing swivel top
  • Flexible Shaft Extension - snake into hard to reach places
  • 60 mm Shaft Extension - doubles as a T-handle for extra torque
  • 1/4" Adapter - use this kit's 4 mm bits in standard 1/4" drivers
  • 54 bits in the following sizes:
    • Pentalobe sizes 2, 5, 6 (iPhone, MacBook Air, MacBook Pro)
    • Flathead sizes 1, 1.5, 2, 2.5, 3, 3.5, 4 mm
    • Phillips sizes #000, #00, #0, #1, #2
    • JIS sizes 000, 00, 0, 1
    • Torx sizes T3, T4, T5, T6
    • Torx Security TR7, TR8, TR9, TR10, TR15, TR20 (compatible with non-security)
    • Hex sizes 0.7, 0.9, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5, 6 mm
    • Square sizes #0, #1, #2
    • Triangle size 3 mm
    • Tri-wing sizes #0, #1
    • Nut Driver sizes 2.5, 3, 3.5, 4, 5 mm
Product Details
$24.95
Condition:
New
Warranty:
One year warranty
$59.95 Wooden Case
Condition:
New
Warranty:
One year warranty
Notes:
Dimensions: 7-7/8" x 4-9/32" x 1-1/2", 200mm x 109mm x 38mm
Add to Cart »
Install Videos
Product Details Edit
This is the set that spawned the repair revolution. We have honed its contents to be both your everyday driver set and your go-to resource for all the security bits needed to open consumer electronics.
Each bit resides in a removable soft plastic block with five friends. The driver body is machined from a single piece of aluminum, with a ball bearing mounted swivel top. The flexible shaft is great for stereo work or other large electronics where all the screws aren’t on the surface. The drive adapter lets you use these specialty bits with any standard ¼” driver handle or most power tools.
When it comes to precision bit sets, there is no better kit. If you want something that looks as elegant as it performs, look no further than the wooden case for the 54 Bit Driver Kit. This case is emblazoned with the Fixers Fist, reminding all the world that we have the right to open our electronics. We believe that repair is noble, and so should you.
Bits Included: ¶
  • Flathead sizes 1, 1.3, 1.5, 2, 2.5, 3, 3.5, 4 mm
  • Nut Driver sizes 2.5, 3, 3.5, 4, 4.5, 5 mm
Stories
jcricca's Story Photo #343970
My Problem
My iPhone 5 power button had gotten to the point where it barely worked. The battery was not so great either, so I figured I'd swap that out while I was in there.
My Fix
The instructions that iFixit provides are clear and accurate. If you take your time, keep the screws organized and don't put undue force on anything, it will go fine. The only thing that irked me was that I sprung for the 54 bit driver kit and the 000 ended up stripping one of first screws I removed. I switched to the cheap phillips head included with the battery kit and it worked perfectly for the remainder of the disassembly.
My Advice
When putting the logic board back in after swapping the power button cable, remember that the power button cable has a connector that runs to the underside of the logic board. If you don't seat this prior to inserting the logic board, the board will wobble and you'll risk warping it if you start putting screws back in.
My Problem
Haven't started yet. However, I do plan on using an electric eel, two chipmunks, and a small Latvian scientist to help me figure it out. Along with several small bits and bytes.
My Fix
This field filled in because the form insisted on it. Bossy scripts.
My Advice
This field intentionally left blank.
My Problem
I'm always working on repairing things so the right tools are critical to being able to do the job. I didn't think of iFixit as a tool source until I saw an article about the 54 bit driver set. Great set of tools! Order process was easy, box arrived quickly, quality tools, great value.
My Fix
This order was preemptive. No repairs YET, just getting the tools before I need them next time.
My Advice
I will definitely think of iFixit whenever I'm looking for additional tools as well as advice/stories/videos on how to fix things. Thanks.
My Problem
Needed to adjust the screw that calibrates the sensitivity of the click on a Macbook Pro 5,1
My Fix
Splendidly. A quarter-turn with the y-wing screwdriver did the trick, and my trackpad is perfectly responsive again.
My Advice
A slightly larger y-wing screwdriver would actually be the perfect fit for the late 2008 Macbook Pro (5,1) I believe it's a #3. Still, this kit is very high quality and worth having on hand if you do a lot of repairs.
My Problem
My father MacBook Pro had a serious trouble with SSD (unstable or non booting computer), thanks to Apple bad quality component. I ordered a new one from iFixit (from which I use guides for maybe ten years), replace it following the appropriated guide, and now everything is fine, the SSD work at full speed on SATA 3GB/s.
My Fix
With no problem (I'm experimented in Apple disassembly with my personal collection of Macs, my family, and the members of my Apple User Group) With my new set of driver from iFixit, I could removed the battery, and put the new cable. I took me about 15 minutes for the whole operation (but I forgot the photos …).
My Advice
No advice, the solution is exactly what we need. Thanks.
My Problem
My iphone 5 had dust in the camera lense, so I took it apart to clean it.
My Fix
The cleaning itself was largely uneventful, though I didn't manage to remove all the dust, and red spots would appear in the camera app. I had to remove the screen protector to get the screen off though, and this proved to be a fatal mistake -- before I could get a replacement I dropped the phone and shattered the screen.
My Advice
Make sure you have a replacement screen protector before you start repairs.
My Problem
No problem. I have had the same kit for a number of years and use it for any number of things. My brother-in-law admired the kit so I ordered one for his birthday.
My Fix
The kit arrived in three days from my order date.
My Advice
Brother-in-law called and thanked me for the gift and said he had a place for it on his repair bench.
My Problem
Had a few problems with Macbook Pro and Macbook Air 11 inch that I am trying to resurrect. Needed the basis tools and was happy with what I got except the Pentalobe P5 needs to be made with a tougher compound as it loses shape too quickly. Keep the faith.
My Fix
Slowly but thats fine, excellent information in the guides and easy for a kiwi to understand even those of us over 70 and Vietnam vets!!
My Advice
Make !@#$ sure you keep the screws in order and accounted for. Most problems are exacerbated by wrong screws and wrong torques. Amazing how impatient you can get as an oldy.
My Problem
Macbook Air got kicked across a wooden floor by a recliner. Fan made a satanic sound. With the help of your screwdrivers I was able to open my computer and unbend a dent in the fan enclosure. Awesome!
My Fix
My Advice
Buy the screwdrivers you need to repair your computer ahead of time.
My Problem
My battery died and was not detectable by my macbook.
My Fix
Easy, just remove few screws and replace the battery, it took me less than 10 minutes do finish the whole thing..
My Advice
Follow the repair guid and use the correct tools, (I used the 54 bit driver kit)
