MacBook Front Display Bezel
$7.99
Product code: IF186-002
Apple Part #: 922-7776, 922-7598, 922-8009
Product Overview
MacBook front display bezel with camera hole. Please note this is only the plastic surrounding the LCD, not the complete display.
Compatibility
Identify your Mac
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Product Details
$7.99 White
Condition:
Used, fully tested
Warranty:
6 month warranty
$29.99 Black
Condition:
Used, fully tested
Warranty:
6 month warranty
Add to Cart »
Replacement Guides
MacBook Core 2 Duo
Difficulty: Difficult
MacBook Core Duo
Compatibility
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
Stories
My Problem
It had begun to crack in a few spots.
My Fix
The repair went very well. I did not need to remove the screen to install the bezel.
My Advice
Be extra careful with the small clips that help hold the bezel. They are delicate. Pry gently and try to avoid damaging the clips. Use a small flat blade to help install the clips being very easy.
My Problem
MacBook mid-2007 13" screen cracked when lid pushed too far back. Front display bezel showed signs of wear so decided to replace it at same time.
My Fix
Parts came on time and safely packed. Printed out guide and followed it religiously. Bought very good small screwdriver set at Home Depot for about $10. Repair successful and fun.
My Advice
To keep up with screws I used Scotch tape to tape each screw on picture in guide as I removed it. That technique made it very easy to return screws to right place when re-assembling. Recommend not snapping Front Display Bezel into place until everything else installed and screen working. Learned that the hard way. At first attempt I failed to firmly seat backlight cable into connector. So, no lighted screen and had to disassemble to properly seat connector. Wish I hadn't snapped bezel in place until everything working. However, mistake was mine not guide's or iFixIt's. Also, the pieces of yellow tape holding down various wires and ribbon cables were easy to remove put did not stick back down very well. Would like to see iFixIt offer small roll of this tape for purchase. I think it's called Kalon tape.
My Problem
Because it was broken in half
My Fix
Very well
My Advice
Always buy from iFixIt.com
