Click Image To Zoom
12.7 mm PATA 8x SuperDrive
$89.95 up to $99.95
Product code: IF153-092
Product Overview
Have you ever thought about what goes on when you slide a CD into your optical drive? The whirr of the spinning CD, the buzz of the lens assembly, the sweet music data pouring from the disk, and, of course, the laser—it's a rock concert for your computer internals.
But what about when your optical drive fails? No lasers, no spinning discs, no rock 'n' roll. The show is cancelled. However, a faulty optical drive doesn't need to be the end of the computer rock tour. By replacing the optical drive, you can get the show back on the road.
Like rock 'n' roll, this drive isn't for everybody and will only fit in 12.7 mm optical bays. It won't work in MacBooks or 15" MacBook Pros, which require a thinner drive. This SuperDrive also won't work in iMacs with Pioneer (DVR-K06RS), or in 14" G4 iBooks with TEAC (DV-W28SL) drives.
NOTE: Requires removing ribbon cable and bracket from your current optical drive for installation.
Compatibility
Identify your Mac
  • G4 Titanium Onyx PowerBooks with combo drives
  • G4 Titanium DVI PowerBooks with combo drives
  • All G4 Aluminum PowerBooks
  • All iBook G4s with Panasonic drives
  • All 17" MacBook Pros (excluding Unibody)
  • All Power PC Mac minis
  • All Model A1176 Intel Mac minis
  • All G5 iMacs
  • All Intel iMacs with Panasonic drives (Early 2008 and older, excluding 24" iMac)
Product Details
  • Speed: 8x DVD-R write
    4x DVD-RW write
    8x DVD+R write
    4x DVD+RW write
    24x CD-R write
    16x CD-RW write
    8x DVD read
    24x CD read
    2.4x DVD+R (DL) write
  • Drivers: No drivers required
  • Compatible Mac OS: 10.2
    10.3
    10.4
    10.5
    10.6
  • Model #: UJ--845, UJ-846, UJ-85J, or UJ-875
$89.95 OEM
Condition:
Used, fully tested
Warranty:
6 month warranty
$99.95 Apple-logo
Condition:
Used, fully tested
Warranty:
6 month warranty
Add to Cart »
Installation Guides
iBook G4 12" 1.33 GHz
Difficulty: Difficult
iBook G4 12" 800 MHz-1.2 GHz
iBook G4 14" 1.42 GHz
Difficulty: Moderate
iBook G4 14" 933 MHz-1.33 GHz
iMac G5 17" Model A1058
iMac G5 17" Model A1144
iMac G5 20" Model A1076
iMac G5 20" Model A1145
iMac Intel 17"
iMac Intel 20" EMC 2105 and 2118
iMac Intel 20" EMC 2133 and 2210
Mac mini (PowerPC)
Mac mini Model A1176
PowerBook G4 Aluminum 12" 1-1.5 GHz
PowerBook G4 Aluminum 12" 867 MHz
PowerBook G4 Aluminum 15" 1-1.5 GHz
PowerBook G4 Aluminum 15" 1.67 GHz
PowerBook G4 Titanium DVI
PowerBook G4 Titanium Onyx
Compatibility
1.33 GHz
1 GHz
1.2 GHz
800 MHz
1.42 GHz
1 GHz (128 RAM)
1 GHZ (256 RAM)
1.2 GHz
1.33 GHz
933 MHz
1.6 GHz
1.8 GHz (EMC No. 1989)
1.8 GHz (EMC No. 2055)
2 GHz
1.9 GHz
1.8 GHz
2 GHz
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
2 GHz (EMC No. 2105)
2.16 GHz
2.33 GHz
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
Mac mini (PowerPC)
1.25 GHz
1.33 GHz
1.42 GHz
1.5 GHz
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.33 GHz (Core 2 Duo)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
1 GHz
1.33 GHz
1.5 GHz
867 MHz
1 GHz
1.25 GHz
1.33 GHz
1.5 GHz (BT 1.1)
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
1.5 GHz (BT 2.0)
1.67 GHz (Low-Res)
1.67 GHz (High-Res)
PowerBook G4 Aluminum 17" 1-1.67 GHz
1 GHz
1.33 GHz
1.5 GHz
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
1.67 GHz (High-Res)
1 GHz
667 MHz
800 MHz
867 MHz
550 MHz
667 MHz
Stories
My Problem
The optical drive stopped working so I decided to shift it. I had a hard time finding a replacement, but found it on iFixit together with an install guide.
My Fix
With the help of install guides on iFixit for RAM and hard drive I had learnt how to disconnect the MacBook Pro. Quite easy actually. The new drive works great.
My Advice
A magnetic bowl for the screws are a good tip and a magnet to make the screwdrivers magnetic to make them hold the screws when unscrewing them and taking them to the bowl and when putting them on place again to fasten them is another tip. I used my fingernails instead of a spudger when lifting up the keyboard.
My Problem
A few parts have gone bad and Apple will no longer fix my computer. Internal power supply and Optical drive. Upgrading to leopard so i boosted the RAM to 2gb.
My Fix
All repairs went very smooth, the repair guides were the key to my confidence. Thanks for everything.
My Advice
For anyone who is as shook as i was before i opened and started poking around in my IMAC G5 1076. Dont sweat it! Its a big LEGO set. A big expensive LEGO set so with a little patience and advise from IFIXIT youll be back up and running in minutes.
My Problem
Roto el ventilador derecho de mi MacBookPro 17", hacía un ruido insoportable, se calentaba la máquina y además de fallar todo el aspecto gráfico y hacer cosas raras como lineas y cuadraditos en la pantalla, a la media hora el poirtátil se apagaba. También tenía roto el Optical Drive desde hace años y el HardDisk de 100Gb iba a pedales....
My Fix
Nervioso al principio... Pero si eres MUY METÓDICO, no eres un manazas, y sigues al pie de la letra las guías, la reparación se hace sencilla y rápida... Yo tardé alrededor de una hora y ningún problema...
My Advice
En los servicios oficiales me pedían un mínimo de una semana y unos 700€ por reparar sólo el ventilador... Las piezas me tardaron en llegar menos de 6 días y sólo me he gastado unos 300... He cambiado el ventilador, el Hardisk por uno de 750Gb y vuelvo a tener Grabadora de DVD... La Máquina va como un tiro... Como el día ke la compré... Adoro IFIXIT.com... Gran Descubrimiento
Related Questions
1 Answer
0 Score
How can I optimize my iBook?
