MacBook Pro 15" Model A1260 Parts
This version of the MacBook Pro 15" includes a logic board processor speed increase.
The MacBook Pro 15" Model A1260 laptop can easily be upgraded to a total of 6 GB of memory using a 4 GB RAM chip and a 2 GB RAM chip. Don't let all that RAM go to waste on a slow hard drive. The 500 GB 7200 RPM SATA hard drive or the 640 GB hard drive will give you plenty of storage. You can even upgrade to a 80 GB SSD hard drive.
Take a look at our MacBook Pro 15" troubleshooting guide for help decoding what's wrong with your machine.
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 73
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $219.95 |
| | MacBook Pro 15" (Model A1260) 2.5 GHz Logic Board2.5 GHz Core 2 Duo Penryn Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0 (high power) | $799.95 |
| | MacBook Pro 15" (Model A1260) Display Assembly1440x900 LED Display / 15.4" | $599.95–$699.95 |
| | MacBook Pro 15" (Model A1260) 2.4 GHz Logic Board2.4 GHz Core 2 Duo Penryn Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0 (high power) | $699.95 |
| | MacBook Pro 15" (Model A1260) Upper CaseUpper case includes palmrest area, multitouch trackpad, trackpad cable, and power button | $249.95–$299.95 |
| | 750 GB Hybrid Seagate SATA Hard DriveSSD speeds from the Momentus XT Hybrid Drive. | $249.95 |
| | 1 TB 5400 RPM Samsung SATA Hard Drive (New)SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM | $249.95 |
| | MacBook Pro 15" (Model A1260) Lower CaseReplace a scratched-up lower case | $239.95 |
| | MacBook Pro 15" (Models A1226/A1260) LCD Panel1440x900 LCD / 15.4" / LED backlight | $199.95–$229.95 |
| | 120 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD | $229.95 |
