13" Unibody Late 2011 Parts
The Late 2011 version of MacBook Pro 13" Unibody is virtually identical to the Early 2011 model except for a CPU and graphics upgrade. It features a Core i5 or Core i7 processor with PC3-10600 RAM. It also sports the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The MBP 13" Unibody (Late 2011) can be upgraded with as much as 16 GB of PC3-10600 RAM in its 2 RAM slots. The 750 GB 7200 RPM SATA hard drive will give you plenty of storage.
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$149.95
MacBook Pro 13" Unibody (Late 2011) 2.8 GHz Logic Board
2.8 GHz Motherboard / Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot
$849.95
MacBook Pro 13" Unibody (Early 2011) 2.3 GHz Logic Board
2.3 GHz Motherboard / Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot
$649.95
MacBook Pro 13" Unibody (Late 2011) 2.4 GHz Logic Board
2.4 GHz Motherboard / Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot
$649.95
MacBook Pro 13" Unibody (Early 2011/Late 2011) Display Assembly
Includes LED assembly and iSight camera.
$499.95
MacBook Pro 13" Unibody (Early 2011/Late 2011) Upper Case
Case assembly includes backlit keyboard.
$299.95
120 GB Solid State Drive Upgrade Kit
Unformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files.
$209.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
MacBook Pro 13" Unibody 8x SATA SuperDrive (Used)
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write
$199.95
750 GB Hybrid Seagate SATA Hard Drive (New)
SSD speeds from the Momentus XT Hybrid Drive.
$199.95
