13" Unibody Early 2011 Parts
In February 2011, Apple refreshed the 13" MacBook Pro line by changing to the Intel HD Graphics 3000, increasing VRAM to 384 MB, and upgrading to Core i5 and Core i7 processors with PC3-10600 RAM. The Mini DisplayPort was also replaced (but still backwards compatible) with the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The Early 2011 MacBook Pro 13" Unibody can be upgraded with up to 16 GB of PC3-10600 RAM. The 750 GB 7200 RPM SATA hard drive will give you plenty of storage.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 51
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $149.95 |
| | MacBook Pro 13" Unibody (Late 2011) 2.8 GHz Logic Board2.8 GHz Motherboard / Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot | $849.95 |
| | MacBook Pro 13" Unibody (Early 2011) 2.3 GHz Logic Board2.3 GHz Motherboard / Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot | $649.95 |
| | MacBook Pro 13" Unibody (Late 2011) 2.4 GHz Logic Board2.4 GHz Motherboard / Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot | $649.95 |
| | MacBook Pro 13" Unibody (Early 2011/Late 2011) Display AssemblyIncludes LED assembly and iSight camera. | $499.95 |
| | MacBook Pro 13" Unibody (Early 2011/Late 2011) Upper CaseCase assembly includes backlit keyboard. | $299.95 |
| | 120 GB Solid State Drive Upgrade KitUnformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files. | $209.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
| | MacBook Pro 13" Unibody 8x SATA SuperDrive (Used)DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write | $199.95 |
| | 750 GB Hybrid Seagate SATA Hard Drive (New)SSD speeds from the Momentus XT Hybrid Drive. | $199.95 |
