MacBook 13" Unibody (Model A1278) Parts
Apple's introduction of the MacBook Unibody 13" introduced a new case milled from a single brick of aluminum. Also new to this version is a switch to SATA optical drives and the controversial loss of a Firewire port.
The MacBook Unibody 13" can be upgraded to 6GB of RAM using a PC3-8500 2 GB RAM chip and a PC3-8500 4 GB RAM chip. The hard drive can also be upgraded to a hefty, yet agile 500 GB 7200 RPM SATA hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your machine above or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 53
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $219.95 |
| | MacBook Unibody (Model No. A1278) 2.4 GHz Logic Board2.4 GHz Motherboard / Ports: Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In, Audio Out | $699.95 |
| | MacBook Unibody (Model No. A1278) Display AssemblyIncludes LED assembly, iSight camera, Bluetooth card, and AirPort card. | $399.95–$499.95 |
| | MacBook Unibody (Model No. A1278) Upper Case (Backlit)Case assembly includes backlit keyboard and trackpad assembly. | $249.95–$299.95 |
| | 750 GB Hybrid Seagate SATA Hard DriveSSD speeds from the Momentus XT Hybrid Drive. | $249.95 |
| | 1 TB 5400 RPM Samsung SATA Hard Drive (New)SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM | $249.95 |
| | 120 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD | $229.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
| | 750 GB 7200 RPM Seagate SATA Hard Drive (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $199.95 |
| | 500 GB Hybrid Seagate SATA Hard DriveSSD speeds from the Momentus XT Hybrid Drive. | $179.95 |
