MacBook 13" Mid 2009 Parts
Apple introduced the Mid 2009 MacBook with a small speed bump and a redesigned heat sink (with no integrated thermal sensors).
The MacBook 13" 2.13 GHz (Mid 2009) laptop can be upgraded to a hefty, yet agile 500 GB 7200 RPM SATA hard drive. A total of 6 GB of PC2-6400 RAM can be installed, using one 4 GB and one 2 GB chip.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
Showing products 1 - 10 of 70
| | 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM. | $219.95 |
| | MacBook (Mid 2009) 2.13 GHz Logic Board2.13 GHz Motherboard / Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $499.95 |
| | MacBook (Early 2009) 2 GHz Logic Board2 GHz Motherboard / Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out | $499.95 |
| | MacBook 13.3" Santa Rosa/Penryn Display Assembly1280x800 LCD / 13.3" | $299.95–$399.95 |
| | 750 GB Hybrid Seagate SATA Hard DriveSSD speeds from the Momentus XT Hybrid Drive. | $249.95 |
| | 1 TB 5400 RPM Samsung SATA Hard Drive (New)SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM | $249.95 |
| | 120 GB Solid State DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD | $229.95 |
| | 750 GB 7200 RPM SATA Hard DriveSATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $209.95 |
| | MacBook 13.3" LCD PanelLCD without the display bezels, hinges, hinge mount or cables / 1280x800 LCD / 13.3" | $149.95–$199.95 |
| | 750 GB 7200 RPM Seagate SATA Hard Drive (New)SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM | $199.95 |
