MacBook 13" Early 2009 Parts
For the Early 2009 version of the MacBook, Apple added liquid damage indicators on the upper case, logic board, and battery connector/sleep sensor. The optical drive is now SATA interface, making this machine incompatible with previous versions. Bluetooth has been updated to version 2.1.
The MacBook 13" 2 GHz (Early 2009) can be upgraded to a total of 6 GB of memory using a 4 GB RAM chip and a 2 GB RAM chip. Don't let all that RAM be wasted with a slow hard drive. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage. The fastest optical drive for this model is the 8x SuperDrive and it will make burning CDs a breeze.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$219.95
MacBook (Mid 2009) 2.13 GHz Logic Board
2.13 GHz Motherboard / Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out
$499.95
MacBook (Early 2009) 2 GHz Logic Board
2 GHz Motherboard / Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out
$499.95
MacBook 13.3" Santa Rosa/Penryn Display Assembly
1280x800 LCD / 13.3"
$299.95–$399.95
750 GB Hybrid Seagate SATA Hard Drive
SSD speeds from the Momentus XT Hybrid Drive.
$249.95
1 TB 5400 RPM Samsung SATA Hard Drive (New)
SATA interface for Intel Macs / Samsung / 2.5" wide x 9.5mm tall / 1 TB Unformatted / 5400 RPM
$249.95
120 GB Solid State Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD
$229.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
MacBook 13.3" LCD Panel
LCD without the display bezels, hinges, hinge mount or cables / 1280x800 LCD / 13.3"
$149.95–$199.95
750 GB 7200 RPM Seagate SATA Hard Drive (New)
$199.95
