Yellow Light of Death Repair
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix consoles plagued with the infamous "Yellow Light of Death".
- Author: Brett Hartt
- Time required: 1 hour
- Difficulty: Difficult
Use this guide to repair PlayStation 3s with the "Yellow Light of Death" error.
Note: Your PlayStation may look slightly different inside. Be cautious when performing this process on your machine.
Sections
- Smart Plate 4 steps
- Top Cover 2 steps
- Blu-ray Disc Drive 3 steps
- Motherboard Assembly 6 steps
- AC Inlet 3 steps
- Rear Cover 2 steps
- Heat Sink 8 steps
Sections (continued)
- Motherboard 13 steps
- Yellow Light of Death (YLOD) Fix Kit 9 steps
Relevant Parts
- View:
- Single page
Edit
Step 9
Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
Be sure you are prying up on the retaining flap, not the socket itself.
Pull the ribbon cable out of its socket.
Remove the Blu-ray drive from the PS3.
If replacing the Blu-ray drive, transfer the power cable to your new drive.
Edit
Step 23
Lift the memory card reader out of the PS3 enough to access its ribbon cable.
Flip up the retaining flap on the memory card reader ribbon cable socket.
Pull the ribbon cable out of its socket and remove the memory card reader.
Edit
Step 28
Lift the motherboard assembly off the heat sink.
The heat sink may still be held in place by the thermal paste. If this is the case, gently pry the heat sink away from the motherboard housing. Make sure to not bend the copper piping on the heat sink.
Be sure to apply a new layer of thermal paste when reattaching the heat sink.
Never applied thermal paste before? Our thermal paste guide makes it easy.
Edit
Step 42
Using the flat end of the spudger, remove the old thermal paste off the CPU and GPU on the motherboard.
Using a cleaner such as Arctic Silver's ArctiClean or Goof-Off, clean the CPU and GPU.
In the same manner as previously described, remove the thermal paste from the heat sink.
Edit
Step 43
Using your fingers or the flat end of a spudger, remove the old thermal pads on the logic board as indicated:
Large square thermal pads
Small Square thermal pads
Small rectangular thermal pads (located on the underside of the board, as highlighted in the second picture)
Some of the smaller thermal pads may be attached to the metal casing that surrounds the motherboard rather than the motherboard itself.
Edit
Step 44
Set the heat gun to "Low", and let it run for a few seconds to reach operating temperature.
Holding the motherboard upright, warm up the entire board with the heat gun. The board should be warm, but not too hot.
This will prevent damage to the board caused by localized thermal expansion.
Edit
Step 45
Set the motherboard on a support so that the CPU and GPU are completely supported and level.
The support should be something that can resist temperatures upwards of 300 degrees Celsius. Suggestions: scrap lumber, old books, cardboard box.
In the next few steps, you will be reflowing the solder under the chips marked in red.
Once you begin reflowing the chips, do not touch or move the motherboard until it is completely cool. Doing so can render the motherboard irreparably damaged.
Edit
Step 48
Ensure that the motherboard has completely cooled before continuing this guide.
If you have not applied thermal paste before you can check our thermal paste guide whilst it is cooling.
Apply a thin bead of thermal paste on the CPU.
Using the thermal paste spreader card, spread the paste out thinly and evenly on the chip.
In the same way, apply a thin layer of thermal paste on the GPU.
Clean up any excess thermal paste off the motherboard.
Page 1 of 1
