iPad Pro 11" 3rd Gen Battery Replacement
  1. iPad Pro 11" 3rd Gen Battery Replacement, Prepare your iPad for disassembly: step 1, image 1 of 1
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 11" 3rd Gen Battery Replacement, Screen removal information: step 2, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Screen removal information: step 2, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Screen removal information: step 2, image 3 of 3
    • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
    • Camera module, ambient light sensors, proximity senor, and front microphone
    • Display cables
    • Screen magnets
    • LCD edges
  3. iPad Pro 11" 3rd Gen Battery Replacement, Heat the right edge: step 3, image 1 of 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
  4. iPad Pro 11" 3rd Gen Battery Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  5. iPad Pro 11" 3rd Gen Battery Replacement: step 5, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 5, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 5, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPad Pro 11" 3rd Gen Battery Replacement: step 6, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement: step 6, image 2 of 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  7. iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: step 7, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: step 7, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: step 7, image 3 of 3
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
    • Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
    • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
    • Insert the tip of an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm or you may damage the LCD.
  8. iPad Pro 11" 3rd Gen Battery Replacement, Separate the right edge adhesive: step 8, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the right edge adhesive: step 8, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the right edge adhesive: step 8, image 3 of 3
    • Insert a new opening pick in the gap you just created.
    • Slide the pick along the right edge to separate the adhesive.
    • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
  9. iPad Pro 11" 3rd Gen Battery Replacement, Heat the top edge: step 9, image 1 of 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  10. iPad Pro 11" 3rd Gen Battery Replacement, Top edge information: step 10, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Top edge information: step 10, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Top edge information: step 10, image 3 of 3
    • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
    • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
    • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
    • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
  11. iPad Pro 11" 3rd Gen Battery Replacement, Separate the top edge adhesive: step 11, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Separate the top edge adhesive: step 11, image 2 of 2
    • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
    • Don't insert the opening pick more than 5 mm.
    • Leave the pick in to prevent the adhesive from re-sealing.
  12. iPad Pro 11" 3rd Gen Battery Replacement: step 12, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 12, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 12, image 3 of 3
    • Insert a new opening pick to the right of the ambient light sensor.
    • Slide the pick along the middle section of the top edge, stopping when you reach the left ambient light sensor.
    • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
  13. iPad Pro 11" 3rd Gen Battery Replacement: step 13, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement: step 13, image 2 of 2
    • Insert a new opening pick to the left of the ambient light sensor.
    • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
    • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
  14. iPad Pro 11" 3rd Gen Battery Replacement, Heat the bottom edge: step 14, image 1 of 1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  15. iPad Pro 11" 3rd Gen Battery Replacement, Separate the bottom edge adhesive: step 15, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Separate the bottom edge adhesive: step 15, image 2 of 2
    • Insert a new opening pick in the bottom right corner below the existing pick.
    • Don't insert the opening pick more than 2 mm when sliding on the right edge.
    • Slide the pick around the bottom right corner to separate the adhesive.
  16. iPad Pro 11" 3rd Gen Battery Replacement: step 16, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement: step 16, image 2 of 2
    • Slide the opening pick along the bottom edge, stopping at the USB-C port.
    • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
    • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
  17. iPad Pro 11" 3rd Gen Battery Replacement: step 17, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement: step 17, image 2 of 2
    • Insert a new opening pick to the left of the USB-C port.
    • Separate the remaining bottom edge adhesive.
    • Don't insert the opening pick more than 5 mm when slicing the bottom edge adhesive.
    • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
  18. iPad Pro 11" 3rd Gen Battery Replacement, Heat the left edge: step 18, image 1 of 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  19. iPad Pro 11" 3rd Gen Battery Replacement, Left edge information: step 19, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Left edge information: step 19, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Left edge information: step 19, image 3 of 3
    • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
    • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
    • There are flat sections of the frame which require an opening pick to be inserted horizontally.
  20. iPad Pro 11" 3rd Gen Battery Replacement, Separate the left edge adhesive: step 20, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Separate the left edge adhesive: step 20, image 2 of 2
    • Insert an opening pick at a 45˚ angle just above the bottom left corner.
    • Don't insert the pick more than 5 mm or you'll damage the display cables.
    • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
  21. iPad Pro 11" 3rd Gen Battery Replacement: step 21, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement: step 21, image 2 of 2
    • Lower the opening pick so it is horizontal to the screen.
    • Don't insert the pick more than 5 mm.
    • Continue separating the left edge adhesive until you reach the next indented section of the frame.
  22. iPad Pro 11" 3rd Gen Battery Replacement, Separate the remaining adhesive: step 22, image 1 of 1
    • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
    • Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
    • Slide the pick horizontally and don't insert the pick more than 5 mm.
  23. iPad Pro 11" 3rd Gen Battery Replacement, Separate the screen from the frame: step 23, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the screen from the frame: step 23, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the screen from the frame: step 23, image 3 of 3
    • At this point, you've separated most of the screen adhesive. Lift the edges of the screen up slightly to check if there is any remaining adhesive.
    • Use an opening pick to remove any remaining adhesive keeping the screen stuck to the frame.
    • Grab the top right and bottom left corners of the screen.
    • Slowly slide the screen towards the bottom right corner to separate it from the frame.
    • Don't fully remove the screen as it is held in place by several ribbon cables underneath.
    • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
  24. iPad Pro 11" 3rd Gen Battery Replacement, Unscrew the ambient light sensor cable bracket: step 24, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Unscrew the ambient light sensor cable bracket: step 24, image 2 of 2
    FixMat
    $36.95
    Buy
    • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
    • One 1.3 mm screw
    • One 2.0 mm screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  25. iPad Pro 11" 3rd Gen Battery Replacement, Remove the ambient light sensor cable bracket: step 25, image 1 of 1
    • Use a pair of tweezers or your fingers to remove the bracket.
  26. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ambient light sensor cable: step 26, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ambient light sensor cable: step 26, image 2 of 2
    • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  27. iPad Pro 11" 3rd Gen Battery Replacement, Reposition the screen: step 27, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the screen: step 27, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the screen: step 27, image 3 of 3
    • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
    • Grip the right edge of the screen and fold it open like a book.
    • Lay the screen down over the left edge of the iPad.
  28. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the lower cable shield: step 28, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the lower cable shield: step 28, image 2 of 2
    • Use a Phillips screwdriver to remove the five screws securing the lower cable shield to the logic board:
    • Two 2.0 mm screws
    • Three 1.3 mm screws
  29. iPad Pro 11" 3rd Gen Battery Replacement, Remove the lower cable shield: step 29, image 1 of 1
    • Use tweezers or your fingers to grab and remove the lower cable shield.
  30. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the battery connector: step 30, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the battery connector: step 30, image 2 of 2
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
  31. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the display cables: step 31, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the display cables: step 31, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the display cables: step 31, image 3 of 3
    • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
  32. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the remaining display cables: step 32, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the remaining display cables: step 32, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the remaining display cables: step 32, image 3 of 3
    • Disconnect the two remaining display cables.
  33. iPad Pro 11" 3rd Gen Battery Replacement, Remove the screen: step 33, image 1 of 1
    • Grip the right edge of the screen and lift it away.
    • During reassembly, before installing a screen, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
  34. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the USB-C port cable: step 34, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the USB-C port cable: step 34, image 2 of 2
    • Use the flat end of a spudger to disconnect the USB-C port cable.
  35. iPad Pro 11" 3rd Gen Battery Replacement, Separate the USB-C cable adhesive: step 35, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the USB-C cable adhesive: step 35, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the USB-C cable adhesive: step 35, image 3 of 3
    • The USB-C port cable is secured to the logic board with weak adhesive.
    • Slide an opening pick between the cable and the logic board to separate the adhesive.
  36. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the USB-C port: step 36, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the USB-C port: step 36, image 2 of 2
    • Use a Phillips screwdriver to remove the two 1.9 mm screws securing the USB-C port to the frame.
  37. iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port grounding contacts: step 37, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port grounding contacts: step 37, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port grounding contacts: step 37, image 3 of 3
    • Use tweezers to remove the two grounding contacts from each side of the USB-C port.
  38. iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port: step 38, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port: step 38, image 2 of 2
    • Lift up and remove the USB-C port.
  39. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the top cable shield: step 39, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the top cable shield: step 39, image 2 of 2
    • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the top cable shield.
  40. iPad Pro 11" 3rd Gen Battery Replacement, Heat the top cable shield: step 40, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Heat the top cable shield: step 40, image 2 of 2
    • Apply a heated iOpener to the top cable shield for one minute to soften the adhesive securing it to the logic board.
  41. iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: step 41, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: step 41, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: step 41, image 3 of 3
    • Insert an opening pick under the top cable shield and gently pry up to separate the adhesive.
  42. iPad Pro 11" 3rd Gen Battery Replacement, Remove the top cable shield: step 42, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the top cable shield: step 42, image 2 of 2
    • Use tweezers or your fingers to grab and remove the top cable shield.
  43. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the IR dot projector cable: step 43, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the IR dot projector cable: step 43, image 2 of 2
    • Use the pointed end of a spudger to disconnect the IR dot projector cable.
  44. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the camera cables: step 44, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the camera cables: step 44, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the camera cables: step 44, image 3 of 3
    • Use the pointed end of a spudger to disconnect the front-facing camera and Face ID camera.
  45. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the front camera assembly: step 45, image 1 of 1
    • Use a Torx T3 screwdriver to remove the two 2.1 mm screws securing the front camera assembly to the frame.
  46. iPad Pro 11" 3rd Gen Battery Replacement, Remove the front camera assembly: step 46, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the front camera assembly: step 46, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the front camera assembly: step 46, image 3 of 3
    • Use the pointed end of a spudger to pry up and loosen the front camera assembly.
    • Use tweezers or your fingers to remove the front camera assembly.
  47. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the two 5G mmWave antenna coaxial cables: step 47, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the two 5G mmWave antenna coaxial cables: step 47, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the two 5G mmWave antenna coaxial cables: step 47, image 3 of 3
    • To disconnect antenna cables like this, use tweezers to grip the connector near the cable and lift it up.
    • Use tweezers to disconnect the two antenna cables.
    • Be careful using tweezers or other pointy metal tools near the battery—a punctured battery may leak dangerous chemicals or cause a fire.
    • To reinstall, hold the connector in place and gently press straight down. The connector will “snap” into its socket much like the metal snaps on a jacket.
  48. iPad Pro 11" 3rd Gen Battery Replacement, Separate the 5G mmWave antenna cables: step 48, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the 5G mmWave antenna cables: step 48, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the 5G mmWave antenna cables: step 48, image 3 of 3
    • The antenna cables are secured to the logic board with weak adhesive.
    • Slide an opening pick under the antenna cables to separate them from the logic board.
  49. iPad Pro 11" 3rd Gen Battery Replacement: step 49, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 49, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 49, image 3 of 3
    • Use an opening pick to separate the thin foam covering the antenna cables.
  50. iPad Pro 11" 3rd Gen Battery Replacement: step 50, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 50, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 50, image 3 of 3
    • The antenna cables are secured to the mmWave interconnect cable with weak adhesive.
    • Slide an opening pick between the antenna cables and the mmWave interconnect cable to separate them.
  51. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the antenna cable bracket: step 51, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the antenna cable bracket: step 51, image 2 of 2
    • Use a Phillips screwdriver to remove the 1.2 mm screw securing the press connector bracket to the logic board.
  52. iPad Pro 11" 3rd Gen Battery Replacement, Remove the antenna cable bracket: step 52, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the antenna cable bracket: step 52, image 2 of 2
    • Use tweezers or your fingers to remove the antenna cable bracket.
  53. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the mmWave flex cable: step 53, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the mmWave flex cable: step 53, image 2 of 2
    • Use the flat end of a spudger to disconnect the mmWave flex cable.
  54. iPad Pro 11" 3rd Gen Battery Replacement: step 54, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 54, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 54, image 3 of 3
    • Slide an opening pick under the mmWave flex cable to separate it from the logic board.
  55. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the rear camera shield: step 55, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the rear camera shield: step 55, image 2 of 2
    • Some of these screws are the same length but have different thread sizes. Don't mix up the screws or you'll damage the threads in the frame.
    • Use your Phillips screwdriver to remove the six screws securing the rear camera shield to the frame:
    • Two 2.8 mm screws
    • One 1.9 mm screw
    • One 1.9 mm screw
    • One 1.2 mm screw
    • One 1.2 mm screw
  56. iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera shield: step 56, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera shield: step 56, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera shield: step 56, image 3 of 3
    • Use tweezers or your fingers to lift the right side of the camera shield up.
    • Slide the shield out horizontally.
    • During reassembly, lower the left side of the shield back into place and make sure the small protruding tab is slotted in, then hinge the shield closed.
  57. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the wide angle camera cable: step 57, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the wide angle camera cable: step 57, image 2 of 2
    • Use the pointed end of a spudger to disconnect the wide angle camera cable.
  58. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the power button and LED cable: step 58, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the power button and LED cable: step 58, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the power button and LED cable: step 58, image 3 of 3
    • Use the pointed end of a spudger to disconnect the power button and LED cable.
  59. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the LiDAR sensor cable: step 59, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the LiDAR sensor cable: step 59, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the LiDAR sensor cable: step 59, image 3 of 3
    • Use the flat end of a spudger to disconnect the LiDAR sensor cable.
    • Fold the LiDAR sensor cable away from the frame to access the press connectors underneath.
    • Only fold the cable enough to access the connector underneath.
  60. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ultra wide camera cable: step 60, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ultra wide camera cable: step 60, image 2 of 2
    • Use the pointed edge of a spudger to disconnect the ultra wide camera cable.
  61. iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera: step 61, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera: step 61, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera: step 61, image 3 of 3
    • Use the flat end of a spudger to gently pry up and loosen the rear camera module.
    • Use tweezers or your fingers to grab and remove the rear camera module.
  62. iPad Pro 11" 3rd Gen Battery Replacement, Logic board removal information: step 62, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Logic board removal information: step 62, image 2 of 2
    • You're about to disconnect many connectors from the top and bottom of the logic board. During reassembly, use these photos as a reference to ensure all cables are connected in the correct locations.
  63. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right speaker cables: step 63, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right speaker cables: step 63, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right speaker cables: step 63, image 3 of 3
    • Use the pointed end of a spudger to disconnect the two top right speaker press connectors.
    • Don't pry against the short sides of the connector. The socket on the logic board is delicate and may break off if pried against.
  64. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left speaker cables: step 64, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left speaker cables: step 64, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left speaker cables: step 64, image 3 of 3
    • Repeat the previous step for the two top left speaker cables.
  65. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top microphone cable: step 65, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top microphone cable: step 65, image 2 of 2
    • Use the pointed edge of a spudger to disconnect the top microphone cable.
  66. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right sensor cable: step 66, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right sensor cable: step 66, image 2 of 2
    • Use the pointed end of a spudger to disconnect the top right sensor cable.
  67. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top interconnect board: step 67, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top interconnect board: step 67, image 2 of 2
    • Use the pointed edge of a spudger to disconnect the top interconnect board.
    • Don't bend or reposition the interconnect board. It's stiff and will break if overbent.
  68. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left antenna cables: step 68, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left antenna cables: step 68, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left antenna cables: step 68, image 3 of 3
  69. iPad Pro 11" 3rd Gen Battery Replacement, Peel back the top logic board shielding: step 69, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the top logic board shielding: step 69, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the top logic board shielding: step 69, image 3 of 3
    • Use tweezers to peel back the logic board shielding tape covering the two antenna cables.
  70. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right antenna cables: step 70, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right antenna cables: step 70, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right antenna cables: step 70, image 3 of 3
    • Use tweezers to disconnect the two bottom right antenna cables.
  71. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect bottom interconnect board: step 71, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect bottom interconnect board: step 71, image 2 of 2
    • Use the pointed edge of a spudger to disconnect the bottom interconnect board.
  72. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Wi-Fi antenna coaxial cable: step 72, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Wi-Fi antenna coaxial cable: step 72, image 2 of 2
    • Use tweezers to disconnect the Wi-Fi antenna coaxial cable.
  73. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Smart Connector cable: step 73, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Smart Connector cable: step 73, image 2 of 2
    • Use the pointed end of a spudger to disconnect the Smart Connector cable.
  74. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right speaker cables: step 74, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right speaker cables: step 74, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right speaker cables: step 74, image 3 of 3
    • Follow the procedure in step 65 to disconnect the bottom right speaker.
  75. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom left speaker cables: step 75, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom left speaker cables: step 75, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom left speaker cables: step 75, image 3 of 3
  76. iPad Pro 11" 3rd Gen Battery Replacement, Reposition the bottom right 5G mmWave antenna cables: step 76, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the bottom right 5G mmWave antenna cables: step 76, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the bottom right 5G mmWave antenna cables: step 76, image 3 of 3
    • Gently pull the antenna cables away from the logic board.
  77. iPad Pro 11" 3rd Gen Battery Replacement: step 77, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 77, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 77, image 3 of 3
    • Continue repositioning the antenna cables until they are clear from the bottom of the logic board.
  78. iPad Pro 11" 3rd Gen Battery Replacement, Peel back the bottom logic board shielding: step 78, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the bottom logic board shielding: step 78, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the bottom logic board shielding: step 78, image 3 of 3
    • Use tweezers or your fingers to peel back the logic board shielding to reveal the hidden press connectors.
  79. iPad Pro 11" 3rd Gen Battery Replacement, Remove the cable bracket: step 79, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the cable bracket: step 79, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the cable bracket: step 79, image 3 of 3
    • Use the flat end of a spudger to slide out the cable bracket.
    • Use tweezers or your fingers to remove the bracket.
  80. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: step 80, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: step 80, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: step 80, image 3 of 3
    • Use the flat end of a spudger to disconnect the left microphone and Apple Pencil charger cables.
  81. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the left edge of the logic board: step 81, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the left edge of the logic board: step 81, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the left edge of the logic board: step 81, image 3 of 3
    • The adhesive that secures the logic board to the frame is very strong. To remove the board, follow the next steps to weaken the adhesive using high-strength (>90%) isopropyl alcohol.
    • Elevate the left side of the iPad so that it lays down at an angle.
    • Apply a few drops of isopropyl alcohol along the left edge of the logic board.
    • Be careful if you're using a syringe with a needle or other sharp instrument to dispense isopropyl alcohol—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Let the alcohol soak for one minute to soften the adhesive under the logic board.
  82. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right edge of the logic board: step 82, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right edge of the logic board: step 82, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right edge of the logic board: step 82, image 3 of 3
    • Rotate your iPad 180˚ and lay it down with the right side elevated.
    • Repeat the previous step for the right edge of the logic board.
  83. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right branch of the logic board: step 83, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right branch of the logic board: step 83, image 2 of 2
    • Elevate the top side of the iPad.
    • Apply a few drops of isopropyl alcohol to the right branch of the logic board near the rear camera glass.
    • Don't allow isopropyl alcohol to contact the rear camera glass or you'll damage them.
    • Let the alcohol soak for one minute to soften the adhesive under the right logic board branch.
  84. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the bottom: step 84, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the bottom: step 84, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the bottom: step 84, image 3 of 3
    • Insert the flat end of a spudger under the lower edge of the logic board.
    • Don't pry against the bottom interconnect board as this will damage it.
    • Slowly lift up the bottom of the logic board.
    • If the adhesive is still too strong to lift up the logic board, apply some additional isopropyl alcohol and wait one minute.
    • Lift up the logic board and replace the playing card battery blocker with an opening pick.
  85. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the left side: step 85, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the left side: step 85, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the left side: step 85, image 3 of 3
    • Slide an opening pick under the left edge of the logic board to loosen it.
    • Pry against the frame underneath the logic board to separate the adhesive.
    • Don't forcefully lever against the battery—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  86. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the top right branch: step 86, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the top right branch: step 86, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the top right branch: step 86, image 3 of 3
    • Use an opening pick to gently pry up the top right branch of the logic board near the rear camera lenses.
  87. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the right edge: step 87, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the right edge: step 87, image 2 of 2
    • Insert an opening pick under the right edge of the logic board above the left microphone and Apple Pencil charger cables.
    • Slide the opening pick under the right edge of the logic board to loosen it.
  88. iPad Pro 11" 3rd Gen Battery Replacement, Remove the logic board: step 88, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the logic board: step 88, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the logic board: step 88, image 3 of 3
    • Use the flat end of a spudger to lift the top edge of the logic board.
    • Grip the top and bottom edges of the logic board.
    • Remove the logic board.
  89. iPad Pro 11" 3rd Gen Battery Replacement, Battery adhesive removal information: step 89, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Battery adhesive removal information: step 89, image 2 of 2
    • There are 11 stretch-release adhesives that secure the battery to the frame. Each adhesive strip has a black pull tab:
    • Six on the inside edge of the left battery
    • Five on the inside edge of the right battery
    • The remainder of the adhesive is located along the bottom edge of the battery.
    • Use your fingernail or tweezers to peel each pull tab from the edge of the battery without removing them.
    • Be careful not to deform or puncture the battery—especially if you're using tweezers.
  90. iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery adhesive: step 90, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery adhesive: step 90, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery adhesive: step 90, image 3 of 3
    • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
    • You can use a spudger to help keep the strip flat while pulling.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but don't pry under the battery.
  91. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol: step 91, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol: step 91, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol: step 91, image 3 of 3
    • If you removed all of the stretch-release adhesive, good job! You can skip the next four steps. If not, then follow the next four steps to apply isopropyl alcohol.
    • Prop the left side of the iPad up against an object so the isopropyl alcohol can flow under the right battery cell.
    • Apply high-strength (>90%) isopropyl alcohol along the inside edge of the right battery cell.
    • Let the alcohol soak for two minutes to soften the adhesive under the battery cell.
  92. iPad Pro 11" 3rd Gen Battery Replacement: step 92, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 92, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 92, image 3 of 3
    • Rotate the iPad 180 degrees so the inner edge of the left battery is facing up.
    • Repeat the previous step on the left battery cell.
  93. iPad Pro 11" 3rd Gen Battery Replacement, Separate the battery adhesive: step 93, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the battery adhesive: step 93, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the battery adhesive: step 93, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • Lay the iPad down flat on your work surface.
    • Starting at the top, insert a plastic card under the right battery cell.
    • Slide the plastic card toward the bottom of the iPad to separate the adhesive.
    • Stop sliding when you reach the Apple Pencil charger cable.
    • Don't force the card or bend the battery. If it's difficult to insert or slide the card, apply more isopropyl alcohol.
  94. iPad Pro 11" 3rd Gen Battery Replacement: step 94, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 94, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 94, image 3 of 3
  95. iPad Pro 11" 3rd Gen Battery Replacement: step 95, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 95, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 95, image 3 of 3
    • Don't try to remove the battery yet – the battery boards are still held in place with adhesive.
    • Lift up the left battery cell.
    • Insert an opening pick under the left battery board and separate the remaining adhesive securing it to the frame.
    • If the adhesive does not separate easily, apply some high-strength (>90%) isopropyl alcohol and wait one minute.
  96. iPad Pro 11" 3rd Gen Battery Replacement: step 96, image 1 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 96, image 2 of 3 iPad Pro 11" 3rd Gen Battery Replacement: step 96, image 3 of 3
    • Repeat the previous step for the right battery cell.
  97. iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery: step 97, image 1 of 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery: step 97, image 2 of 2
    Tesa 61395 Tape
    $10.99
    Buy
    • Lift both halves of the battery out of the iPad at the same time.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove the old battery adhesive from the frame using tweezers and high-strength (>90%) isopropyl alcohol with a lint-free cloth where needed.
    • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 3rd Gen Answers community for help.
2 other people completed this guide.
Chayton Ritter
18,004 Reputation
99 Guides authored
Guide Team Member of Guide Team
Staff
6 Members
7,250 Guides authored
0 Comments
Past 24 Hours: 18
Past 7 Days: 134
Past 30 Days: 554
All Time: 6,671
