Installing iPhone 5 Front-Facing Camera and Sensor Cable
Remove the front-facing camera and rear microphone assembly from your iPhone 5.
  • Add Note x
  • x 6
The front-facing camera and rear-facing microphone are on a single cable, and must be replaced together. Use this guide to remove this assembly.
Image #1
Add Note Edit Step 1 — Front Panel Assembly  ¶
  • Before disassembling your iPhone, be sure it is powered off.
  • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
Image #1
Add Note Edit Step 2  ¶
  • Press a suction cup onto the screen, just above the home button.
  • Be sure the cup is completely on the screen to get a tight seal.
Image #1
Add Note Edit Step 3  ¶
  • Make sure the suction cup is firmly attached to the front panel assembly.
  • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
  • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
  • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
  • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
Image #1
Add Note Edit Step 4  ¶
  • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
  • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
  • Lift and rotate the front panel assembly up to about 90 degrees from the rear case.
Image #1
Add Note Edit Step 6  ¶
  • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • One 1.6 mm Phillips screw
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Remove the front panel assembly cable bracket from the logic board.
Image #1 Image #2 Image #3
Add Note Edit Step 8  ¶
  • Use a plastic opening tool to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • Digitizer cable
    • LCD cable
      • When reassembling your phone, The LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best was to power cycle your phone is to disconnect and reconnect the battery.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Small Suction Cup
$2.95 · 50+ In stock
Plastic Opening Tools
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
