Antenna
2 Answers 1 Score |
No power or screen display in.my tablet |
1 Answer 0 Score |
I lost my AC adapter |
1 Answer 2 Score |
Why is the tablet rebooting its self |
1 Answer 1 Score |
Go's from android home screen to a Bot standing with door open |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are experiencing any troubles with the RCA 10 Viking Pro RCT6K03W13, refer to our troubleshooting page
Background and Identification
The RCA 10 Viking Pro RCT6K03W13 was released in 2017. The model number is located on a sticker on the outside of the back plate. What makes the RCA 10 Viking Pro RCT6K03W13 and other similar models is how cheap it is.
The tablet also comes with a keyboard which allows you to use it as a laptop as well. To use the keyboard you want to connect the keyboard connector to the side of the tablet.
The appearance of the device is very basic. It is a full screen with one button used for powering on and off, and a volume changing button located on the back of the tablet. Located on the side of the device, there is a headphone jack, USB port, micro USB port, and a DCIN port. It was only manufactured in a single color, which is an all black screen and a space grey back cover. However, the keyboard can be purchased in an array of colors.
The RCA viking pro 10 is a small 2 in 1 tablet with a connectable keyboard. The tablet weighs 2 pounds and has the dimensions of 10.95" x 0.79" x 6.89". The model number is physically located on the center of the back-plate of the device. You can tell the difference from this device apart from others mainly due to its unique dimensions, along with the RCA logo on the back of the tablet. The device comes in more than one color, including pink, gray, blue, yellow, and more. Users will be able to identify this device with the RCA logo on the back of the device, along with the speaker on the back of the tablet.
Specifications
- Operating System: Android 5.0
- Chip: Quad Core
- Resolution: 1280×800
- Screen: 10.1″ IPS
- RAM: 1GB
- RAM Type: DDR SDRAM
- Capacity: 32GB
- Front Facing 2 megapixel webcam
- Rear 2-megapixel webcam
- Battery Life: 6 Hours
- Weight: 2.29LBS
