RCA 10 Viking Pro RCT6K03W13 Antenna Replacement
  1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: step 1, image 1 of 3 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: step 1, image 2 of 3 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: step 1, image 3 of 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: step 2, image 1 of 2 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: step 2, image 2 of 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: step 3, image 1 of 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: step 4, image 1 of 2 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: step 4, image 2 of 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Antenna: step 5, image 1 of 1
    • Identify the grey wire on the right side of the device.
  6. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: step 6, image 1 of 1
    • Remove the orange ribbon cable over the wire.
  7. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: step 7, image 1 of 1
    • Remove the antenna using a soldering iron.
Ryan Wickett
632 Reputation
3 Guides authored
One Comment
Does anyone know where I can buy a new antenna for this device?
DIY_Human - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 400
