RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: step 1, image 1 of 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: step 1, image 2 of 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: step 1, image 3 of 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 2, image 1 of 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 2, image 2 of 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 3, image 1 of 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 4, image 1 of 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 4, image 2 of 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: step 5, image 1 of 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 6, image 1 of 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 7, image 1 of 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 8, image 1 of 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 8, image 2 of 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 9, image 1 of 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 9, image 2 of 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: step 10, image 1 of 1
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 11, image 1 of 1
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 12, image 1 of 1
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: step 13, image 1 of 1
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 14, image 1 of 1
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: step 15, image 1 of 1
    • Remove the motherboard.
Marcus Elysee
97 Reputation
1 Guide authored
One Comment
Where can I buy this motherboard?
waymond everett - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,359
