Click Image To Zoom
160 GB 5400 RPM Western Digital ATA Hard Drive (New)
$149.95
Product code: IF107-046-1
Product Overview
Years of research and experimentation has shown that saving information to a spinning platter is a safer alternative to filing it in a lump of pizza dough or stapling it to a whirling dervish. Modernize data vertigo today with our 160 GB 5400 RPM Western Digital ATA hard drive.
Does not work in MacBook, MacBook Pro, MacBook Air, or Intel Mac Minis.
Compatibility
Identify your Mac
  • All iBook G4s
  • All Aluminum PowerBooks
  • All PowerPC Mac minis
Product Details
  • Manufacturer: Western Digital
  • Speed: 5400 RPM
  • Dimensions: 2.5" wide x 9.5mm tall
  • Capacity: 160 GB Unformatted
  • Buffer Size: 8 MB
  $149.95
Condition:
New
Warranty:
3-year manufacturer warranty
Add to Cart »
12 Available
Quantity:
Installation Guides
iBook G4 12" 1.33 GHz
Difficulty: Difficult
iBook G4 12" 800 MHz-1.2 GHz
iBook G4 14" 1.42 GHz
iBook G4 14" 933 MHz-1.33 GHz
Mac mini (PowerPC)
Difficulty: Moderate
PowerBook G4 Aluminum 12" 1-1.5 GHz
PowerBook G4 Aluminum 12" 867 MHz
PowerBook G4 Aluminum 15" 1-1.5 GHz
PowerBook G4 Aluminum 15" 1.67 GHz
Compatibility
1.33 GHz
1 GHz
1.2 GHz
800 MHz
1.42 GHz
1 GHz (128 RAM)
1 GHZ (256 RAM)
1.2 GHz
1.33 GHz
933 MHz
Mac mini (PowerPC)
1.25 GHz
1.33 GHz
1.42 GHz
1.5 GHz
1 GHz
1.33 GHz
1.5 GHz
867 MHz
1 GHz
1.25 GHz
1.33 GHz
1.5 GHz (BT 1.1)
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
1.5 GHz (BT 2.0)
1.67 GHz (Low-Res)
1.67 GHz (High-Res)
PowerBook G4 Aluminum 17" 1-1.67 GHz
1 GHz
1.33 GHz
1.5 GHz
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
1.67 GHz (High-Res)
Stories
My Problem
Failed Hard Drive - Machine would not boot from HD. I Purchaed the Hard Drive and the recommended Tool Set with prying tools and the Bit Drive Kit which I found all to be essentail! I could not have done the repair without them. THANK YOU ifixit!!!! - You have a life long customer!
My Fix
Seamlessly! Your detailed step by step instructions were invaluable! It would have taken me hours to figure out how to dissaasembly. Your notes and tips were exactely on mark. It made the reapir quick and easy, which bit size to use saved a ton of time. Even the notes on Eraseing the HD first before installing OS!
My Advice
Setting up double sided tape on a sheet of paper to hold the small screws was a life saver. I also labled Step number and parts location next to the screws - which made reassembly a breeze.
My Problem
The iBook in this story was passed down from my sister to my mother, then given to me since, as my mother says, it stopped working. After booting the device from a Disk Warrior disk, I determined the unit needed a new hard drive.
I spent a few months researching the cost and steps necessary for putting a new drive in the iBook and found the iFixit site. The process looked intimidating. I could see a few steps where I was sure I was going to damage things beyond repair, but decided to proceed all the same. What did I have to lose? I was enticed by the thought of having a working Mac laptop for the cost of a new hard drive.
I did briefly contemplate allowing the blue-themed big box technology store do the install, but decided against it when the clerk told me it would only take 30 minutes. I had seen the steps on iFixit. Not only did I not believe it could be done in 30 minutes, I didn't believe it could be done well in 30 minutes.
I ordered all my parts from iFixit, including a RAM upgrade, since I was going to have the iBook opened up already.
My Fix
I had a second laptop with the installation guide from iFixit opened for reference. I don't think I would have been able to do this task without it.
I made sticky notes for each step, on which I placed the screws removed during that step, set on a diagram of where the screws were located relative to the laptop. This helped me stay organized.
I somehow missed the note that I was going to need a T8 Torx tool and had to go out to Wal-Mart at 11:30 pm to purchase one. Of the two Torx sets I own, neither had a tool smaller than T10.
I did end up with one extra screw--one I missed in the replacement of the upper shield. I think the reference photo for this step was confusing for me. I also lost one of the springs from the battery compartment. I found it the next morning, but I'm not willing to re-open the iBook to install it.
My Advice
It takes more force than I thought to get the plastic case removed. This is anxiety-producing. I was sure I was going to crack it beyond use. I also stressed over damaging the connectors on the mother board, but they are not as fragile as I thought.
Use the spudger to push/pry and move things. It is a wonderful tool.
This is the most difficult computer repair/installation I have ever attempted and I am extremely happy that it was successful. I would not even have attempted it without iFixit.
Related Questions
