Click Image To Zoom
128 GB Solid State Drive
$134.95
Product code: IF107-123
Product Overview
A 128 GB Solid State Drive with the tools needed to swap it in.
  • Super fast, SanDisk's top of the line X210 128 GB SSD.
  • Hard Drive enclosure used for transferring your files also converts your old drive into a handy external USB drive.
  • Don't get caught with the wrong equipment this kit has everything it takes to get into most laptops.
  • Use the free SuperDuper! to transfer your files with the enclosure.
Kit Contents:
Compatibility
  • All MacBooks and MacBook Pros (excluding MacBook Air and MacBook Pro Retina)
  • All Intel Mac minis
Product Details
  • Interface: SATA 6.0 Gb/s
  • Dimensions: 2.5" (69.85mm) wide x .27" (7mm) tall
  • Capacity: 128 GB Unformatted
  • Read: Up to 505 Mb/s
  • Write: Up to 470 Mb/s
$134.95 Upgrade Kit
Condition:
New
Warranty:
5-year manufacturer warranty
Notes:
This option contains the drive and kit components.
$119.95 Drive only
Condition:
New
Warranty:
Notes:
SanDisk X210
Model #: SD6SB2M-128G-1022I
Add to Cart »
Replacement Guides
Mac Mini Mid 2010
Difficulty: Moderate
Mac mini Model A1176
Mac mini Model A1283
MacBook Core 2 Duo
Difficulty: Easy
MacBook Core Duo
Difficulty: Easy
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2009
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 17" Unibody
MacBook Unibody Model A1278
Difficulty: Easy
MacBook Unibody Model A1342
PlayStation 3
PlayStation 3 Slim
Compatibility
Mac Mini Late 2012
2.3 GHz (Quad i7, Late 2012)
2.5 GHz (Dual i5, Late 2012)
2.6 GHz (Quad i7, Late 2012)
Mac Mini Mid 2011
2 GHz (Quad i7, Mid 2011)
2.3 GHz (Dual i5, Mid 2011)
2.5 GHz (Dual i5, Mid 2011)
2.7 GHz (Dual i7, Mid 2011)
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
2 GHz (Core 2 Duo, A1283)
2.26 GHz (A1283)
2.53 GHz (A1283)
2.66 GHz (A1283)
Mac mini Model A1347
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 13" Unibody Early 2011
2.3 GHz (Early 2011)
2.7 GHz (Early 2011)
MacBook Pro 13" Unibody Late 2011
2.4 GHz (Late 2011)
2.8 GHz (Late 2011)
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.66 GHz (Mid 2010)
MacBook Pro 13" Unibody Mid 2012
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Early 2011
2 GHz (Early 2011)
2.2 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz (Late 2008)
2.53 GHz (Late 2008)
2.66 GHz (Early 2009)
2.8 GHz (Late 2008)
2.93 GHz (Early 2009)
MacBook Pro 15" Unibody Late 2011
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
MacBook Pro 15" Unibody Mid 2012
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
3.06 GHz (Mid 2009)
MacBook Pro 17" Unibody Early 2011
MacBook Pro 17" Unibody Late 2011
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2 GHz (A1278)
2.4 GHz (A1278)
2.26 GHz (A1342)
2.4 GHz (A1342)
Stories
My Problem
Installed SSD for use as fusiondrive with onboard HHD
My Fix
Went well although design of bluetooth antenna was different than repair plan showed. Succeded anyway
My Advice
Just look very carefully and then just do it!
My Problem
Slow startup
My Fix
Relocate HD into the optical Bay adapter.
Install new SSD.
My Advice
Needed advice out of different forums:
- to make an backup and to restore
- to create an USB startup stick (maverricks)
- to 'create' (simulate) an CoreStorage: FusionDrive
Everything worked out well. The MBP is faster and the temperature stays lower than before.
Thanks to your good mechanical Instructions on the website and the tools you delivered with the SSD disk. GREAT experience! It is a pleasure to work with you!!!!
Sincererly,
Iwan Meier.
