Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
How to tell GB of iPhone without turning it on?
Hello,
I wanted to know if there was a way to tell if an iPhone is 8,16, or 32GB without turning it on. Like through the serial number or the logic board.
Score 1
Add a comment
Chosen Solution
The problem with getting the number of the case, is that the case may have been changed. Check the chipset. The memory chip is on the "underside" of the logic board and is most likely a Toshiba.Do a search of that number and it should tell you which memory capacity your phone has. i.e. Toshiba TH58G6D1DTG80 being a 8GB IC. Hope this helps, good luck.
Score 1
Add a comment
Look at the rear of the phone, below where it says "iPhone". On mine there is a square with "8GB" in.
Add a comment
Add your answer
Matthieu will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 8
All Time: 12,485
