Score
rohde5
23
Asked
home button re-install on touch 2g
replacing home button and metal support with ribbon that lie below button (under the bezel. there is a gold "ladder type " spring below ribbon circuit. is this suppose to be in contact with ribbon circuit when i put bezel back on iPod or is it only suppose to touch that gold piece connected to mb when you press the home button
Score
Josh Calvetti
3.8k
Answered
Accepted Answer
It needs to touch that gold piece of tape on the bezel.
so if i have this right-that gold (z-spring) soddered to mb is ALWAYS suppose to be touching the circuit tape on underside of bezel. if that is true, i assume when you press the home button, it then pushes down the gray "click disk" below it and that makes a "short" of some sort to send iPod to main menu? BTW: do you know if the other gold contact that is just to the left of the charging port is always suppose to be in contact with the metal bracket on underside of bezel? if so, could you "activate" the same function the home button performs by taking a piece of wire and touching both gold contacts? the reason that i ask is that my screen remains "white" (think it is frozen state) and i am trying to reboot by home button/power button technique holding sequence. if i can get it un-froze, i am just going to use "ihome/mquickdo
0
Score
barlowdo
279
Answered
0
Score
Answered
0
Score
pebenson
Answered
