Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 Questions View all
CD stuck and making noise
Hello!, i have a 27 inch imac from mid 2010.
Some time ago i had a problem in wich i put a memory stick in the cd reader accidentally, as u know, the cd slot on the imac take the cd inside and u cant take it off by hand. so what i did is open the imac using the tutorial from this page, and i unsrew the cd player and i took it move it until i reach the memory stick stuck indise. then i screw it back in the imac and i closed, but since that day some cd's (not all) that i put in the imac stuck inside and i have to use a clip to move it a little to make it eject.
the question is: it is possible that i screw the cd player too hard and that make it moved or misplace and that cause the cd's i put to stuck inside?
other problem i have is that when they read some cd's it make noise. what can cause all that, maybe somthing i did when i opened the imac?
Thanks !
Score -1
Add a comment
1 Answer
Chosen Solution
Sounds like it was not lined up with the ejection port. Try re-reasting the drive. Use an old disk that doesn't matter and try inserting it to make sure you got it in the correct position.
Score 3
1 Comment:
I know that some screws are screwed with a determined force to be exactly lines. maybe i forced too much. thanks
by
Add a comment
Add your answer
Ignacio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 698
