0
Score
Avatar
Andre Gois
Asked
Red Vertical Lines on Screen where Black Areas should be
History
My 15" 2007 Macbook Pro started displaying Red Vertical Lines on Screen where Black Areas should be.
I've tried some things to try and solve it, but none worked:
- Did a PRAM and SMC reset.
- Checked the connection on the Display Data Cable
- Replaced the entire Screen Assembly (including inverter, lcd, and all cables). Got the parts from a similar MBP from a friend that has a dead logic board.
The only reason I'm not sure if this is a Logicboard/GPU problem is the problem doesn't occur on an external screen.
Does anyone have any idea what more I should look into?
Edited by: Andre Gois ( )
Post Answer
Score
Avatar
mayer
150.7k
Answered
PermalinkHistory
This sounds exactly like the nVidia GPU 8600 graphics chip type issue. To be sure please give us the last three figures of your serial number.
Edited by: mayer ( )
Thank you for your answer. But the GPU is a "ATI Radeon X1600 256 MB". The serial is ****900VW0L.
Andre Gois,
Apple MacBook Pro "Core 2 Duo" 2.33 15" Specs Identifiers: Late 2006 - MA610LL - MacBookPro2,2 - A1211 - 2120
mayer,
The symptoms don't make sense. If you've replace everything from the logic board up it must be confined to the logic board or GPU. Check your external monitor again with several screens. "when you have eliminated the impossible, whatever remains, however improbable, must be the truth", sherlock holmes
mayer,
Yeah.. your right.. I suspect the Display Data Cable Plug on the Logic Board might be the problem... But that's beyond my skills. I'm going to send it in to Apple (here in Portugal) get an estimate on a repair (if at all possible)... Thank you all!
Andre Gois,
The parts you got are the probable cause. How do you know they were working?
mayer,
0
Score
Avatar
loweseditora
Answered
PermalinkHistory
Fortaleza, julho de 2012
Caro André,
Sou professor da Universidade Estadual do Ceará e, no momento, estou produzindo uma obra intitulada Quantos Brasis, de certo modo inédita no País, por tratar-se de uma abordagem interdisciplinar entre Literatura, Geografia e História do Brasil, que deverá ultrapassar as 2.000 páginas.
Por tratar-se de uma obra volumosa e realizada com recursos de um professor universitário e algumas poucas doações, venho solicitar a V. Sa. a autorização para inserir a foto de sua autoria em nosso trabalho, encontrada na URL http://www.panoramio.com/photo/23213684.
Estamos dando, como é justo além de legal, o devido crédito ao autor de cada fotografia (obra de arte), momento em que aproveitamos para agradecer seu gesto de compreensão e colaboração com esta iniciativa cultural.
Gratíssimo,
Prof. Francisco Coêlho Sampaio
Não sou o mesmo Andre Gois que tirou essa foto. Boa sorte!
Andre Gois,
0
Score
Avatar
danieladro
Answered
PermalinkHistory
Caro Andre,
Estou com o mesmo problema, mesmo após substituir o inverter cable. Neste momento, estou incerto se devo avançar para a substituição do Painel LCD ou se, como diz, o problema será outro.
Chegou a ter algum feedback da própria Apple?
0
Score
Avatar
Vinnicius Almeida Zanini
Answered
PermalinkHistory
I fix this problem reflow in Nvidia processor. is not a lcd or flat cable problem
Add Your Answer
