Repair guides and troubleshooting information for hair dryers.
29 Questions View all
My Rowenta Hair Dryer 2000kw does not blow hot air anymore!
Hi everyone,
I have a rowenta hair dryer which has stopped heating up right away. It blows cold air only. It has 2 speed buttons and 1 cold air (not needed anymore!!!!) one. Can u guys help me? TXXXXXX!
Add a comment
Chosen Solution
The heating coil probably has a break in it (most common cause for failure). The problem is getting a good replacement part. It does have a one year warranty: http://www.rowentausa.com/rowenta/frame....
Score 2
Add a comment
well I recommend you to buy a new one, normally when it starts to fail it's better to get a better one. If you decide to do that, I suggest the one I use, it's the Karmin G3 Salon Pro Hair Dryer which dries the hair really fast and keeps my hair smooth, shiny, frizz less and healthy. :D If you are interested you can check it out at safrons. com :D
Good luck. :)
Add a comment
well im just gessing but when you turn on the hair dryer check and see if the heating elememts inside are heating up if not then i would replace the heater coil if that dident work then i would do as Brownmoniq says and just buy a new one because if its not the coil then is has something to do with the control board
Add a comment
Add your answer
Laurie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 5,625
