0
Score
rdburkh
Asked
Difference between iPhone 4 and 4G Digitizers?
Is there a difference between the digitizer and LCD between an iPhone 4 and an iPhone 4 4G? Are all iPhone 4 phones 4G? I'm looking to buy a replacement screen for my iPhone 4, but all the ones I find are being called iPhone 4 4G...will it work as long as it's the AT&T model?
2
Score
oldturkey0
88.1k
Answered
rdburkh , "None of the iPhones on the market support 4G service, which provides faster data connections on mobile phone networks than the standard existing 3G networks. The confusion may stem from the fact that many of these users probably have the iPhone 4, which itself succeeded the third-generation iPhone 3G and 3GS. But the "4" in the name means only that it's the fourth generation of the phone itself, not the service. AT&T(T) and Verizon(V)subsc
iPhone 4 Display Assembly (GSM/AT&T)
Includes the LCD and the front panel glass. — 50+ available at 94.95 each.
Score
Peter
13
Answered
Hi,the AT&T Digitizer and CDMA Digitizer are the same,but the clip of the frame are different.And 4S digitizer is difference from At&t and CDMA digitizer,becau
You can check this http://www.priorparts.com/blog/differenc...
0
Score
Brad
8.4k
Answered
The digitizers are all the same. The only difference is in the screen mounting bracket, the spacing of the screws tabs are all different on the 3 different iPhone 4.
Regarding 4G, Apple considers the iPhone 4S to be a 4G capable phone. I think Apple is wrong. But when iPhone 4S on iOS 5.1 achieves optimum through-put the iPhone screen will display 4G next to the Carrier Name.
Vendors will even worse use 4G to mean, any of the 3 different iPhone 4, which is bad. The 3 iPhone 4 are:
iPhone 4 GSM
iPhone 4 CDMA
iPhone 4S
0
Score
Laurie
13
Answered
there's a bad batch of iphone 4s lcd assemblies going around, just purchased 5 of them, 3 white 3 black... all 3 black were bad, they don't fit, there's a good extra millimeter at least in thickness difference when you compare them to a good one, if you try to force it down then you'll end up with a white hazy ring around the screen from the pressure put on the LCD, these are OEM lcd's as well (apple on the cable), I bought these locally too, not straight from China on Ebay... makes me nervous about buying any online, atleast locally I can take them back and now check what he gives me for the giant gap between the lcd and the digitizer! If you get one that doesn't fit nicely, that's the problem
0
Score
tolgar
25
Answered
the digitizers and LCD are fused together,, Both digitizers are totally the same. iPhone 4 Digitizers are compatible with 4G, vice versa......http://www.prezzydeal.com/lcd-touch-digi...
