Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Questions View all
Is this a stripped display assembly hinge press fit? Suggested hacks?
My MacBook Pro has a fully loose display hinge. After taking it apart, I believe what happened is that the holes where the hinges are press fit into the display assembly have been stripped but I’m not 100% sure since I don’t have an example on hand of what the press fit points are supposed to be like so I’d appreciate a knowledgeable second look. Both the left and right hinges easily fell out of the display assembly. There’s dark gray substance that seems like graphite on the push fit pin and flakes of it are spilling out of the push fit hole. I don’t know why a lubricant would be here though. Maybe it’s ground up aluminum?
This is the most closely related existing thread I could find:
The hinges snapped. Is there anyway to replace the hinges?
From searching online, my understanding is that there aren’t any removable pieces on the display so the only full fix would be a replacement display. Considering the age of the laptop and the cost of a replacement display, I don’t think it would make financial sense to go that route. Are there any recommendations for a hack repair? The obvious option is to try glueing the hinges in place. Any strong opinions for how to prep the surfaces or what adhesive to use?
Thanks!
Add a comment
1 Answer
Chosen Solution
Sadly yes Apple on the first series 2016/17 did use a press fit pin design, later the went into a key way design which prevented this issue as the display won’t stay at the angle you wish.
Apple did have a extended service offering for this issue but I think that’s expired at this point. The only option from Apple would be replacement of the display assembly which is quite expensive.
I have been successful using cyanoacrylate glue to hold things. After fully cleaning the pin and hole of any junk and greases use a toothpick to wipe the inner hole and quickly press the pin in making sure you get it in fully.
Score 1
2 Comments:
I glued the hinges in place and the results are good. I see that you're a prolific answerer here and I'm sure it's an often a thankless task so I want to give a big thanks on behalf of all us randos who come to forums like this in our personal times of crisis with our questions. You people are angels. Thanks!!
by
@khouli - Thanks! Just my ecology minded effort! Trying to keep as many older systems running as long as possible!
by
Add a comment
Add your answer
Kevin Houlihan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 32
All Time: 32
