Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
104 Questions View all
Webcam connector location on A2179
Hi,
I have replaced the screen assembly on a MacBook Air early 2020 (A2179) and there is a note on the back of the screen advising to make sure the display and camera connections are correctly connected.
Is this the same connector for both? As I can only see one connector that I removed when I took the screen off.
Also, I need to test it but can only use the guest account until the owner returns on Friday. Does the standard guest account have permissions to use the webcam?
Thanks in advance,
G
Add a comment
1 Answer
There are five cables involved with the display:
You have the four from the display connecting to the T-CON board and then you have one cable coming from the logic board to the T-CON.
If the display is showing that validates the two wider display cabled and the video side of the logic board cable. That leaves one of the smaller cable connections from the display which is the camera feed and the other is the display back light feed. If you look carefully the copper lines are bigger on the backlight cable.
That then leaves the logic board or camera cable which could have damaged connector contacts or traces within the cables.
Add a comment
Add your answer
Gerald Bowen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 33
