Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Questions View all
Determine if there is a SATA SSD or Blade SSD installed
Hey fellow fixers!
I am trying to determine, prior to opening it up whether a late 2013 iMac has a Blade or 2.5 inch SATA SSD installed.
Essentially, this iMac had its original spinning HDD upgraded to a SSD, but I was not the tech who did that upgrade. Now I need to open it up to possibly recover data from the drive and I want to make sure I have the proper enclosure for the process.
I don’t know if the person who did the upgrade installed a blade type SSD or a 2.5 inch SSD.
Is there a way to determine this for sure in system information so I can be sure prior to cracking this thing open?
Thanks in advance!
@danj
Add a comment
1 Answer
Chosen Solution
If the system is still running, go into About This Mac and click on System Report. Now click in SATA/SATA Express and NVM Express tabs to see what is present for drives. Jumping to Storage gives you the volumes report.
Score 1
1 Comment:
Add a comment
Add your answer
Milo Firestar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 25
All Time: 25
