Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
211 Questions View all
TouchID deserializing after disassembly?
Specs:
MacOS Sonoma Build # 14.1 (23B74)
Ram: 32GB
Storage: 2TB
Graphics: Dual Graphics AMD Radeon Pro 5500M + Intel UHD Graphics 630
So here's the thing, I received this MacBook from the marketplace from an elderly woman who gave me a great deal on it. After receiving, I installed a fresh OS of Ventura and setup the system normally. AppleID, TouchID, and passcode all set as normally and functioning normally.
This laptop runs fantastic and is my daily driver, but a few weeks later, I decided I wanted to repaste the cpu for adequate cooling since the old paste was a bit crusty. I will note that I am experienced with disassembly, and if there was something I didn't know, I simply followed the ifixit guide.
After successfully assembling everything back together and successfully booting back into MacOS (upgraded to Sonoma at launch), I unlocked my laptop with the passcode naturally. Noticed that the temps were fantastic and didn't notice the problem at hand until I needed to unlock my MacBook again.
See when I needed to use it again, I needed to use the passcode again, and at first I thought it might've been a time limit thing. So I locked the laptop, and tried to unlock it again with my fingerprint, only to find that my fingerprint wasn't working. So I figured, no problem, I'll just register a new print, only to find that no matter what I tried, I kept getting the "TouchID failed" message. I also found that the button altogether was not responding at all, no matter how long I held it down, it didn't shut down, or turn the display off at all. There is no liquid damage, or overuse at all. I contacted apple and went through the steps they provided, no luck. I proceeded to search online for possible fixes and tried everything. I even took it back apart to make sure that the ribbon cable was fully seated and not damaged, even in the slightest. After confirming that it wasn't hardware, I continued my search online.
I eventually came across this thread on another forum saying something about the TouchID being "serialized", which left me with a sinking feeling as I have no idea as to how to serialize the TouchID.
Would it be possible that the TouchID was "deserialized" during disassembly? If so, is there a way to fix this issue without paying the premium at apple to get it "repaired". They quoted me over $300 for the "repair" and I highly doubt that its a hardware issue, more like apple's way to stop the "right to repair" by serializing all of their components and likely deserializing components during disassembly without an authorized apple technician.
If this is the case, will an apple "repair" be my only option, or is there a solution to this?
Thanks for the patience with this long intro, and thanks for any input.
Add a comment
1 Answer
Let’s first talk about the TouchID button, the button is programmed specifically to only work with its mated logic board. As long as the two stay together there is no hardware level issue with serialization.
So that leaves the programming of the button with your finger print. If you had a working setup before you disassembled things the finger print is still held within the buttons EEROM area. So the disconnection of the button or loss of power won’t loose the stored finger print. So I think we can rule that out as well.
What is left is possible damage either with the button or the ribbon cable which is a bit fragile! And the last is the connection point to the logic board either the ribbon is not inserted correctly or the ZIF connector is not latched.
As we are getting into winter we need to be careful with static electricity zapping something are you using proper ESD protection? Also did you follow the guides on Disabling Auto Boot before taking things apart?
Sadly, I think you may need to visit Apple to get the system fixed. While Apple has made things tougher for self repair, I’ve not had issues with the button, but I’ve seen a few mangled ribbon cables here and in person.
1 Comment:
So i will clarify that I did this static free, making sure I was not zapping anything. Also I'll mention that I performed the disassembly before winter, maybe 4 months ago. And unfortunately, I may have forgotten to disable auto boot.... I don't know how I forgot that....... Would that potentially break something withing the components? Also I will mention that while I was troubleshooting the TouchID, I tried fixing it by manually deleting the saved fingerprints in settings. So I don't have any of the prints saved. I can check the cable again in a bit. Also, if I disable autoboot next time I take things apart, would I be able to boot up if my power button is nonresponsive?
by
Add a comment
Add your answer
Aaron Sales will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 57
