Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Questions View all
Which LCD screen should I look for?
Hi
I have a late 2012 27 inch iMac and the bottom left and right LED banks are failing. I am getting the fan shaped dimming on the screen.
I am just wondering if that year iMac has a specific screen that I need to be looking for or are there others that are compatible?
I don't really want to separate the screen from the body as yet as I am still using the iMac daily so I can't get to the part number.
The model iMac is A1419 and the EMC is 2546.
Any help would be greatly appreciated.
1 Comment
Thankyou for replying. I've done a few screen swaps in the past but I wasn't sure if screens were specific to EMC and model years etc. Apart from the 4K and 5K screens, I just assumed they would work.
I didn't know that the LED's can be replaced.
by
Add a comment
1 Answer
Chosen Solution
You do need to use the correct display assembly for your system, here’s the guide to properly get it off and the steps to install a new one iMac Intel 27" EMC 2546 Display Replacement and here’s the needed part iMac 27" LCD Display Panel & Front Glass Assembly (12/13) keep an eye out as they pop up! They will be used as they are no longer being made.
Even still, you might find a used system to salvage the backlight unit and just swap it out.
1 Comment:
by
Add a comment
Add your answer
Sheldon Griffin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 12
All Time: 46
