Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Can a hard drive in an optical drive caddy be used as the main drive?
The previous owner removed all the fittings for the main drive, and the main drive cable is broken, so I wondered if a drive in the optical drive caddy could be used as the main (only) drive? I only ever see references to using it as a second drive.
Add a comment
1 Answer
Chosen Solution
I have never tried this myself, but I don't see why not. Even with the Optical drive installed, it's still possible to set that as a boot option, and theoretically, it could be set as the default startup disk if you installed macOS onto it.
Score 2
Add a comment
Add your answer
Rob Chambers will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 19
