Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
115 Questions View all
Device not turning on after speaker replacement
Hi guys. I opened my Macbook Pro M1 2020. I disconnected the battery connecters, as I saw in the iFixit guide. I replaced the speakers. Connected and assembled but did not turn on.
Battery was 80 percent before opening. Macbook was in sleep mode. Tried charging, changed cable/charger, tried Power Cycle and different key combination. No luck. Any help would be very grateful.
Add a comment
Did you wear an ESD grounding strap when doing the repair? The electrostatic discharge could also cause potential damage when doing those kinds of repairs, especially on macs.
3 Comments:
I think you're right i tried to ground myself before disconnecting the battery. This might be the issue. What could be the possible damage?
by
It could be a few things on the board, it would be hard to tell specifically what it is without having it in front of me. There's a lot of small components that could be shorted, deeming it inoperable. You might have to use a multimeter and work your way from the charging port to figure out which components might be blown.
by
I sent it to a repair shop. They said some Sound IC is busted and charging section, they are not more clear but you know what it is.
by
Add a comment
I would check the ribbon cables and the logic board connectors. Take some good pictures of the connections and post them here so we can review things.
Add a comment
Add your answer
Ali Chaudhary will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 60
