The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
628 Questions View all
Replaced logic board, now getting blinking question mark Folder
Pretty much what it says in the title, I replaced the logic board using the instruction guide and everything went as planned, but upon powering on, I see the blinking question mark folder.
Add a comment
In your case the logic boards static PRAM data is looking for the drive it had before or if it’s a new logic board it’s not set.
Here you need to first leverage the startup disk control Option (⌥) from your keyboard to then manually select the drive, then after it has booted up go to your systems preferences to set the startup disk so it’s set.
Reference: Mac startup key combinations
Add a comment
usually an hdd issue
Score -1
Add a comment
Add your answer
John Menna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 30
