2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Question Closed
Heatsink paste req'd or no?
Replacing logic board on a1342 and altho the directions here talk of using paste, plus its visible in picture, plus when I lifted off heat sink the paste is visible YET an educated answer from someone here said in my model it wasent needed. Expensive gamble and I need truth and/or general consensus-HELP???? THNX.
3 Comments
Could you give a link to that educated answer?
by
What he was saying was that if there was a heatsink already attached to the new board there is no need to pull it off to put your heatsink on. If your new board has no heatsink attached to it already and you are going to use your heatsink for the new board you will need thermal paste.
by
thanku justin
by
Add a comment
Chosen Solution
Whenever you replace the processor or heatsink new thermal compound/paste is required. I recommend Arctic Silver 5. The thermal compound needs to be spread evenly and a very thin layer. Too much can increase temperatures and cause problems.
Score 1
Add a comment
Do I require an EXACT match to replace my logic board?
Add a comment
AB Cellers is right. You need Arctic Silver 5 and can buy it at Radio Shack if you need it fast. You can order it on e-bay if your cheap and need to save some cash. Cut a piece of plastic off of the package or use one of those fake American Express Credit cards their always sending to your house and use it as a spreader. Wear some gloves if you don't like that gray stuff from the tube getting on your hands.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 675
