Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
210 Questions View all
Wrong battery percentage being reported after battery change
Question:
Any ideas on how to fix so that the OS reports the correct battery percentage?
Context:
  • I changed the battery on my own.
  • The computer charges fine up to what is being reported by the OS as 100%.
  • After disconnecting the power cable the OS will soon report the battery percentage to be 1%.
  • I am able to run the computer fine on 1% for an hour or so.
  • Battery condition is reported as "normal" by the OS.
Symptom:
Update (08/29/23)
Thank you for your answer.
I just tried resetting SMC but it didn't help.
CoconutBattery when power cable is disconnected:
CoconutBattery when the power cable was just connected:
CoconutBattery when the power cable has been connected for 5 minutes:
Add a comment
1 Answer
I would start off resetting SMC and then leave the system to charge over night fully powered off.
I would also down load this Gem of an App CoconutBattery let’s see what it tells us. Post a snapshot of the Apps main screen here so we can see it to.
Update (08/29/23)
@tedlindstroem - Not good! 😞
I would replace the battery again as it does look like the microcontroller within it is defective in this battery. Contact the seller to get a replacement.
Add a comment
Add your answer
Ted Lindström will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 73
