Can I take a hard drive from an iMac and boot from it on my MacBook Pr
Can I take a hard drive from an iMac and boot from it on my MacBook Pro to use the iMac as a portable computer?
Can you explain your reason here a bit more.
Are you wanting to access the iMacs data from your MacBook Pro? Either locally or remotely.
Are you trying to setup your MacBookPro as a replacement of your iMac?
You don’t need to remove the drive from your iMac to attain that!
Screen is destroyed and it’s a work computer and need to work in the interim
@bg234 - Which system has the damaged display? iMac or MacBook Pro and which model as that also effects the answer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 34
